Raspbian GNU/Linux 9 (stretch)
Linux 4.14.79-v7+
Raspberry Pi 3 Model B Rev 1.2
openjdk version "1.8.0_152"
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
openHAB 2.4.0-1 (Release Build)
Logged error
[WARN ] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
org.openhab.core.transform.TransformationException: An error occurred while loading script.
Content of MQTT message
shellies/<denSensor>/sensor/temperature 74.75
Item definition
Number den_Temperature
"Temperature - Den [%.2f F]"
(gTemperature)
{ mqtt="<[broker:shellies/<denSensor>/sensor/temperature:state:JS(tempSensor.js)]" }
/srv/openhab2-conf/transform/tempSensor.js
Javascript transform function to adjust the value received from the den sensor
(function(i) {
if (i == 'NULL') { return i; }
if (i == '-') { return 'Undefined'; }
return (parseFloat(i) - 1.0);
})(input)
I want the value that ends up being stored in the Item to be 1.0 less than the value received. For this example 73.75
The Community topics I was able to find didn’t shed light on my issue.
Does the tempSensor.js
file have to have the execute permission? I didn’t want to just try this without reason and I didn’t find anything to answer this question elsewhere.
Thanks for your help.
Mike
