hi,
my robotermower succesfully reports it`s driving distance in meters:
Number Landroid_totalDistance "Total Distance [%s m]" <lawnmower> {mqtt="<[broker:landroid/status/totalDistance:state:default]"}
I`d like to transform the number from meters in kilometers.
posts in other topics show examples by using JS transformation, so I tried:
Number Landroid_totalDistance "Total Distance [JS(kilometer.js):%s km]" <lawnmower> {mqtt="<[broker:landroid/status/totalDistance:state:default]"}
and the file kilometer.js in the transform folder:
(function(i) {
return (i/1000);
}) (input)
unfortunately the script does not work, the item in the sitemap just reports “NaN”. I do not get any failure in the logs.
“Javascript Tranformation” add-on is installed…
any idea whats wrong?
I know I can achieve the same result with a rule like that:
var Number Landroid_km = Landroid_totalDistance.state as DecimalType
var Number yy = Landroid_km/1000
postUpdate(Landroid_totalDistance_km, yy)
but there are some other statistics from that mower that are reported in minutes. I`d like to transform them to hours or days as well. the JS way of doing that seems to be much easier than to write a rule for every single item…
thanks
What happens if you apply the transform to the message in the MQTT transform instead of the label? I suspect what is happening is the km is also being passed to the JavaScript transform from the label. It has been a long long time but I believe I’ve seen this issue crop up before and IIRC an issue was even created. Guess it never got fixed.
That helps for the KM -> M conversion.
I’ve this JS that converts minutes to days:hours:mins that you can extend as necessary.
(function(i) {
if(isNaN(i)) return "NAN";
var mins = i%60
var totalhours = Math.floor(i/60)
var hours = totalhours%24
var days = Math.floor(totalhours/24)
var pad = "00";
return days+":"+(pad+hours).slice(-pad.length)+":"+(pad+mins).slice(-pad.length)+":00";
})(input)
Javascript transform function to change the number
of minutes of CPU time from the System Info Binding
into a more readable format
eg: 2365 into '1 day 15 hours 25 minutes
The item in the items file is defined as follow:
Number LocalComputer_Cpu_SystemUptime "[JS(CPUTime.js):%s]"
and linked via PaperUI to the System uptime channel
of the System Info Thing
(function(i) {
if (i == 'NULL') { return i; }
if (i == '-') { return 'Undefined'; }
var val = parseInt(i); // The value sent by OH is a string so we parse into an integer
var days = 0; // Initialise variables
var hours = 0;
var minutes = 0;
if (val >= 1440) { // 1440 minutes in a days
days = Math.floor(val / 1440); // Number of days
val = val - (days * 1440); // Remove days from val
if (val >= 60) { // 60 minutes in an hour
hours = Math.floor(val /60); // Number of hours
val = val - (hours * 60); // Remove hours from val
minutes = Math.floor(val); // Number of minutes
var stringDays = ''; // Initialse string variables
var stringHours = '';
var stringMinutes = '';
if (days === 1) {
stringDays = '1 day '; // Only 1 day so no 's'
} else if (days > 1) {
stringDays = days + ' days '; // More than 1 day so 's'
} // If days = 0 then stringDays remains ''
if (hours === 1) {
stringHours = '1 hour '; // Only 1 hour so no 's'
} else if (hours > 1) {
stringHours = hours + ' hours '; // More than 1 hour so 's'
} // If hours = 0 then stringHours remains ''
if (minutes === 1) {
stringMinutes = '1 minute'; // Only 1 minute so no 's'
} else if (minutes > 1) {
stringMinutes = minutes + ' minutes'; // More than 1 minute so 's'
} // If minutes = 0 then stringMinutes remains ''
var returnString = stringDays + stringHours + stringMinutes
return returnString.trim(); // Removes the extraneous space at the end
})(input)
thanks for the fast response, you were both right!
indeed, the “km” from the label
was forwareded to the js and therefore failed. it works without “km” but then I was missing the unit in the sitemap.
the magic “Number:Length” does the trick, it can also convert to cm, dm, miles etc, greate! it even shows the correct decimal point “,” instead of “.”
both minutes convertion .js work fine, but wouldn`t be the “Number:Time” magic also worth to be implemented?
Number Landroid_totalTime "Total Time [JS(minutestohours.js):%s]" <lawnmower> {mqtt="<[broker: landroid/status/totalTime:state:default]"}
