[Solved] JSON array? loop it in rule; rapid fire rule: concurrency?
The "$.[" + i +"]" got me on the right path.
the rule looks like this now (I have commented it for better comprehension):
rule "Sonoff sensors"
        Item rtl_1_DataReceived changed
        // rtl433_json contains recieved JSON string
        val String rtl433_json = (rtl_2_DataReceived.state as StringType).toString
        // rtl_433 capture string:
        // rtl_433 -X 'n=Sonoff-DW2,m=OOK_PWM,s=304,l=820,r=7992,g=752,t=204,y=0'
        // -F json | mosquitto_pub -h 192.168.1.5 -p 1883 -t ArgyleCourt/Shed/testing -l
        // model used by all sensors (added by RTL433)
        val String model = transform("JSONPATH", "$.model", rtl433_json)
        // The PIR sends two signals, identified as follows:
        // time      : 2020-11-04 12:45:44
        // model     : Generic-Remote
        // House Code: 54978
        // Command   : 190
        // Tri-State : 1ZZX100XX11X
        // {"time" : "2020-11-04 16:40:06", "model" : "Generic Remote", "id" : 54978, "cmd" : 190, "tristate" : "1ZZX100XX11X"}
        // model     : Smoke-GS558
        // id        : 27163
        // unit      : 11
        // learn     : 0
        // Raw Code  : 7d436b
        // {"time" : "2020-11-04 16:40:06", "model" : "Smoke detector GS 558", "id" : 27163, "unit" : 11, "learn" : 0, "code" : "7d436b"}
        //val String sensor_id = transform("JSONPATH", "$.id", rtl433_json)
        //if (sensor_id == "54978")
        //    logInfo("Sonoff.0.00", "rtl433_json..............: {}", rtl433_json)
        // listening to the PIR sensor
        if (model == "Generic-Remote")
            val String json_copy_1 = rtl433_json
            val String PIR_id = transform("JSONPATH", "$.id", json_copy_1)
            //logInfo("Sonoff.1.00", "rtl433_json..............: {}", json_copy_1)
            logInfo("Sonoff.1.01", "model....................: {}", model)
            logInfo("Sonoff.1.02", "PIR_id...................: {}", PIR_id)
            switch PIR_id
                case "54978":
                    // Shed_NLO_PIR
                    Shed_NLO_PIR_LUP.postUpdate(new DateTimeType())
        // listening to the Sonoff-DW2 contact sensors
        if (model == "Sonoff-DW2")
            val String json_copy = rtl433_json
            val Number num_rows = Integer::parseInt(transform("JSONPATH", "$.num_rows", json_copy))
            logInfo("Sonoff.1.03", "model....................: {}", model)
            logInfo("Sonoff.1.04", "num_rows.................: {}", num_rows)
            // {"time" : "2020-11-04 22:29:35", "model" : "Sonoff-DW2", "count" : 2, "num_rows" : 2, "rows" : [{"len" : 25, "data" : "5bd73e8"}, {"len" : 6, "data" : "5c"}], "codes" : ["{25}5bd73e8", "{6}5c"]}
            // {"time" : "2020-11-04 22:29:37", "model" : "Sonoff-DW2", "count" : 2, "num_rows" : 2, "rows" : [{"len" : 25, "data" : "5bd73e8"}, {"len" : 16, "data" : "5bd7"}], "codes" : ["{25}5bd73e8", "{16}5bd7"]}
            // {"time" : "2020-11-04 22:38:17", "model" : "Sonoff-DW2", "count" : 4, "num_rows" : 4, "rows" : [{"len" : 25, "data" : "5bd73e8"}, {"len" : 25, "data" : "5bd73e8"}, {"len" : 23, "data" : "5bd73e"}, {"len" : 0, "data" : ""}], "codes" : ["{25}5bd73e8", "{25}5bd73e8", "{23}5bd73e", "{0}"]}
            // checked: it is valid JSON!
            //   "time" : "2020-11-04 22:38:17",
            //   "model" : "Sonoff-DW2",
            //   "count" : 4,
            //   "num_rows" : 4,
            //   "rows" : [
            //     {"len" : 25, "data" : "5bd73e8"},
            //     {"len" : 23, "data" : "5bd73e"},
            //     {"len" : 0, "data" : ""}
            //   "codes" : [
            //     "{25}5bd73e8",
            //     "{25}5bd73e8",
            //     "{23}5bd73e",
            //     "{0}"
2020-11-05 11:04:52.403 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'sonoff.rules'
2020-11-05 11:05:53.359 [INFO ] [marthome.model.script.Irrigation1.t1] - ..< turning ............................ Irrigation1_3 OFF
2020-11-05 11:05:59.518 [INFO ] [e.smarthome.model.script.Sonoff.1.03] - model....................: Sonoff-DW2
2020-11-05 11:05:59.523 [INFO ] [e.smarthome.model.script.Sonoff.1.04] - num_rows.................: 1
2020-11-05 11:05:59.537 [INFO ] [e.smarthome.model.script.Sonoff.1.05] - probeString..............: {len=1, data=8}
2020-11-05 11:05:59.550 [INFO ] [e.smarthome.model.script.Sonoff.1.06] - dataLength...............: 1
2020-11-05 11:05:59.564 [INFO ] [.smarthome.model.script.Sonoff.1.07a] - dataValue................: 8
2020-11-05 11:05:59.579 [INFO ] [e.smarthome.model.script.Sonoff.1.05] - probeString..............: {"time" : "2020-11-05 11:05:51", "model" : "Sonoff-DW2", "count" : 1, "num_rows" : 1, "rows" : [{"len" : 1, "data" : "8"}], "codes" : ["{1}8"]}
            var i = 0
            var String dataLength = ""
            var String probeString = ""
            var String Sonoff_DW_id = "123456"
            while (i <= num_rows) {
                // should return the len:data pair; e.g. {"len" : 25, "data" : "5bd73e8"}
                // 2020-11-05 10:00:49.479 [INFO ] [e.smarthome.model.script.Sonoff.1.05] - probeString..............: {len=1, data=8}
                probeString = transform("JSONPATH", "$.rows.[" + i + "]", json_copy)
                //logInfo("Sonoff.1.05", "probeString..............: {}", probeString)
                if (probeString.length() < 25)
                    logInfo("Sonoff.1.06", "probeString..............: {}", probeString)
                    // 2020-11-05 10:00:49.488 [INFO ] [e.smarthome.model.script.Sonoff.1.06] - dataLength...............: 1
                    dataLength = transform("JSONPATH", "$.rows.[" + i + "].len", json_copy)
                    logInfo("Sonoff.1.07", "dataLength...............: {}", dataLength)
                    if (dataLength == "25")
                        Sonoff_DW_id = transform("JSONPATH", "$.rows.[" + i + "].data", json_copy)
                        logInfo("Sonoff.1.08", "Sonoff_DW_id.............: {}", Sonoff_DW_id)
                        // exit out of while after having found one complete id (len =25)
                        // since break and return lead to undesired results,
                        // up the i to exit out of while()
                        i = num_rows.intValue
                i++
            switch Sonoff_DW_id
                case "5bd73e8":
                    // KDL kitchen window
                    Shed_NLO_Window_Kitchen_LUP.postUpdate(new DateTimeType())
                // ... and all others :)
However, I feel there is a concurrency problem.
Both sensors, the PIR and door contact send multiple messages; the PIR being the worst, sending 20 plus messages every time something moves.
I thought I could trick the rule in finishing one execution before being triggered again. (That was a silly idea.)
Maybe I have to use locks??
I read Rich’s Explain lock() command?, and locks should be avoided, but how else can I prevent the rapid firing of the rule?
