I just upgraded to 2.3 and now a script of mine stopped working which gets sensor values periodically from a json via http
import org.openhab.core.library.types.*
import org.openhab.model.script.actions.*
rule "Sensor"
when Time cron "0 0/2 * 1/1 * ? *" //every two Minutes
var String URL= "http://192.168.1.66/data.json"
var String json = sendHttpGetRequest(URL)
var String P10
P10=transform("JSONPATH", "$.sensordatavalues[0].value", json)
postUpdate(PM10 , P10)
I’m getting
2018-06-16 05:16:00.105 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert ‘{“software_version”: “NRZ-2018-103”, “age”:“135”, “sensordatavalues”:[{“value_type”:“SDS_P1”,“value”:“15.73”},{“value_type”:“SDS_P2”,“value”:“14.23”},{“value_type”:“BME280_temperature”,“value”:“22.25”},{“value_type”:“BME280_humidity”,“value”:“65.18”},{“value_type”:“BME280_pressure”,“value”:“81969.86”},{“value_type”:“samples”,“value”:“603283”},{“value_type”:“min_micro”,“value”:“230”},{“value_type”:“max_micro”,“value”:“25200”},{“value_type”:“signal”,“value”:"-75"}]}’ to a state type which item ‘PM10’ accepts: [DecimalType, QuantityType, UnDefType].
Seems like it doesn’t extract the values at all anymore and just stores the full file in the variable. It did work until before the update.
Can anyone point me in the right direction?
