You’ll want to become familiar with that repo, since scripted automation without the helper libraries would be extremely tedious. There is also a PR I have yet to review for a Docker installation script…
I meant a Jython script engine add-on that will simplify the installation. If you are running then play! Shout if you need anything! The Jython add-on could take months.
2019-09-30 23:48:46.656 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'javascript/core/000_startup_delay.js'
2019-09-30 23:49:17.795 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/000_startup_delay.py'
2019-09-30 23:49:49.310 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/100_DirectoryTrigger.py'
2019-09-30 23:49:51.427 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py': ImportError: No module named configuration in <script> at line number 21
2019-09-30 23:49:51.429 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/100_OsgiEventTrigger.py'
2019-09-30 23:49:53.458 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py': ImportError: No module named configuration in <script> at line number 17
2019-09-30 23:49:53.460 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/100_StartupTrigger.py'
2019-09-30 23:49:55.243 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_StartupTrigger.py': ImportError: No module named configuration in <script> at line number 16
2019-09-30 23:49:55.244 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonBindingInfoProvider.py'
2019-09-30 23:49:56.849 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py': ImportError: No module named configuration in <script> at line number 19
2019-09-30 23:49:56.850 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonExtensionProvider.py'
2019-09-30 23:49:58.780 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py': ImportError: No module named configuration in <script> at line number 29
2019-09-30 23:49:58.781 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonItemChannelLinkProvider.py'
2019-09-30 23:50:00.734 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py': ImportError: No module named configuration in <script> at line number 18
2019-09-30 23:50:00.743 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonItemProvider.py'
2019-09-30 23:50:02.702 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py': ImportError: No module named configuration in <script> at line number 10
2019-09-30 23:50:02.708 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonThingProvider.py'
2019-09-30 23:50:04.609 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py': ImportError: No module named configuration in <script> at line number 17
2019-09-30 23:50:04.610 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonThingTypeProvider.py'
2019-09-30 23:50:06.439 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py': ImportError: No module named configuration in <script> at line number 17
2019-09-30 23:50:06.441 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/core/components/200_JythonTransform.py'
2019-09-30 23:50:07.942 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonTransform.py': ImportError: No module named configuration in <script> at line number 19
2019-09-30 23:50:07.951 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script 'python/personal/hello_world.py'
2019-09-30 23:50:11.207 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/personal/hello_world.py': ImportError: No module named configuration in <script> at line number 5
not sure if it’s worth debugging, still feels quite rough for production use
You need to follow all the steps in the installation instructions. Your issue is at step 8 (rename /automation/lib/python/configuration.py.example). It looks like the docker docs need an update.
You could setup Karaf for ssh, but it’s easier to use the $OPENHAB_RUNTIME/bin/client script. Another option is to edit the $OPENHAB_USERDATA/etc/org.ops4j.pax.logging.cfg file and manually add the logger.
