Platform information:
- Hardware: Raspberry Pi 2
- OS: openHABian 1.4.1
- Java Runtime Environment: Zulu Embedded OpenJDK
- openHAB version: latest
Issue of the topic:
After following steps in “Install openHABian (Recommended)” I found that after booting system for the first time, can’t install Zulu Embedded OpenJDK due to (tried Oracle Java with the same error):
gpg: keyserver receive failed: No keyserver available
FAILED (keyserver)
seems like it’s an issue with dirmngr, found similar problems, where proposed solution was to:
apt -y install dirmngr
In my case it doesn’t solve the problem.
Seems like currently openHABian image is broken.
- If logs where generated please post these here using code fences:
2018-06-09_12:06:22_CEST [openHABian] Checking for root privileges… OK
2018-06-09_12:06:22_CEST [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2018-06-09_12:06:22_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-405(218edec)
2018-06-09_12:06:23_CEST [openHABian] Checking for changes in origin… OK
2018-06-09_12:06:30_CEST [openHABian] Installing Zulu Embedded OpenJDK…
$ apt -y install dirmngr
Reading package lists… Done
Building dependency tree
Reading state information… Done
dirmngr is already the newest version (2.1.18-8~deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.$ apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 219BD9C9
Executing: /tmp/apt-key-gpghome.6bxquwC3QT/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 219BD9C9
FAILED (keyserver)
