Hi
i have upgraded from KNX1 to KNX2 and have the following issues:
- as soon openhab is up i’m not able to programm any device via ETS5 (worked before)
- All my contact items do not work
- getting Datapoint reading retries until maximum reached.
Any idea ?
knx.things
Bridge knx:ip:bridge [
ipAddress="192.168.0.8",
portnumber=3671,
localIp="192.168.0.167",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="1.1.1"
Thing device generic {
Type switch : Light_KG_Flur_Decke "Flur Keller Decke" [ ga="1/0/100+<1/0/100" ]
Type switch : Light_KG_Buero_Decke "Buerolicht" [ ga="1/0/112+<1/0/112" ]
Type switch : Light_KG_Waschkeller_Decke "Waschkeller" [ ga="1/0/130+<1/0/130" ]
Type switch : Light_KG_Regal_Decke "Regal" [ ga="1/0/111+<1/0/111" ]
Type switch : Light_KG_Vorrat_Decke "Vorrat" [ ga="1/0/120+<1/0/120" ]
Type switch : Light_EG_Wohnzimmer_White "Wohnzimmerlicht" [ ga="1/0/221+<1/0/221" ]
Type switch : Light_EG_Esszimmer "Esszimmerlicht" [ ga="1/0/220+<1/0/220" ]
Type switch : Light_EG_Esszimmer_Tisch "Esszimmer Tisch" [ ga="1/0/226+<1/0/226" ]
Type switch : Light_EG_Wohnzimmer_Rainbow "Regenbogen" [ ga="12/0/231+<2/0/231" ]
Type switch : Light_EG_Terasse_Mauer "Gartenbeleuchtung" [ ga="1/0/230+<1/0/230" ]
Type switch : Light_EG_Terasse_Markise "Lichterkette" [ ga="1/0/231+<1/0/231" ]
Type switch : Light_EG_Kueche_Decke "Kueche Arbeitsplatte" [ ga="1/0/252+<1/0/252" ]
Type switch : Light_EG_Kueche_Table "Kueche Tisch" [ ga="1/0/251+1/0/251<" ]
Type switch : Light_EG_Flur_Garderobe "EG Flur" [ ga="1/0/210+<1/0/210" ]
Type switch : Light_EG_GaesteWc_Decke "EG GasteWc" [ ga="1/0/240+<1/0/240" ]
Type switch : Light_EG_Tueroeffner "Tueroeffner" [ ga="0/0/15+<0/0/15" ]
Type switch : Light_EG_Haustuer_auf "Haustuer auf" [ ga="0/0/12+<0/0/12" ]
Type switch : Light_OG_Bad_Decke "OG Badezimmer" [ ga="1/0/136+<1/0/136" ]
Type switch : Light_OG_Flur_Decke "OG Flur" [ ga="1/0/54+<1/0/54" ]
Type switch : Light_OG_Emelie_Decke "OG Licht Emelie" [ ga="1/0/114+<1/0/114" ]
Type switch : Light_OG_Jonathan_Decke "Licht" [ ga="1/0/104+<1/0/104" ]
Type switch : Light_OG_Schlafzimmer_Decke "Schlafzimmer" [ ga="1/0/124+<1/0/124" ]
Type switch : Light_Hoflicht "Hoflicht Eingang" [ ga="0/0/8+<0/0/8" ]
Type switch : Nachabschaltung_Jonathan "Nachtabschaltung Jonathan" [ ga="0/0/16+<0/0/16" ]
Type switch : Nachabschaltung_Emelie "Nachtabschaltung Emelie" [ ga="0/0/17+<0/0/17" ]
Type switch : Nachabschaltung_Schlafzimme "Nachtabschaltung Schlafzimmer" [ ga="0/0/18+<0/0/18" ]
Type switch : Shutter_EG_Wohnzimmer_Markise "Markise" [ ga="5/0/227+<5/0/227" ]
Type switch : Shutter_EG_Wohnzimmer_Markise1 "Markise 50%" [ ga="5/0/228+<5/0/228" ]
Type switch : Leinwand_Oben "Rolladen EG Wohnzimmer Leinwand oben" [ ga="3/0/230+<3/0/230" ]
Type switch : Leinwand_Unten "Rolladen EG Wohnzimmer Leinwand unten" [ ga="3/0/231+<3/0/231" ]
Type switch : Bewegung_KG_Treppe "Bewegungsmelder KG Treppe" [ ga="11/0/20+<11/0/20" ]
Type switch : Bewegung_EG_Flur "Bewegungsmelder EG Flur" [ ga="11/0/21+<11/0/21" ]
Type switch : Bewegung_OG_Flur "Bewegungsmelder OG Flur" [ ga="11/0/22+<11/0/22" ]
Type switch : Bewegung_EG_WC "Bewegungsmelder EG WC" [ ga="11/0/23+<11/0/23" ]
Type switch : Bewegung_OG_Bad "Bewegungsmelder OG Bad" [ ga="11/0/24+<11/0/24" ]
Type switch : Bewegung_OG_Bad_Dusche "Bewegungsmelder OG Bad Dusche" [ ga="11/0/26+<11/0/26" ]
Type switch : Bewegung_KG_Buero "Bewegungsmelder KG Buero" [ ga="11/0/25+<11/0/25" ]
Type switch : Alarm_Drainage "Alarm Drainagepumpe defekt" [ ga="9/0/0+<9/0/0" ]
Type switch : Nachtabsenkung "Heizung Nachtabsenkung" [ ga="8/0/17+<8/0/17" ]
Type switch : Komforttemperatur "Komfortemperatur" [ ga="8/0/18+<8/0/18" ]
Type switch : WW_Zirkulation "Warmwasser Zirkulation" [ ga="0/0/13+<8/0/13" ]
Type switch : Helligkeit1 "Dach Helligkeitswert 1 Licht" [ ga="0/0/20+<0/0/20" ]
Type switch : Helligkeit2 "Dach Helligkeitswert 2 Licht" [ ga="0/0/21+<0/0/21" ]
Type switch : HelligkeitRollo "Dach Helligkeitswert Rollo" [ ga="0/0/1+<0/0/1" ]
Type dimmer : Light_EG_Wohnzimmer_White_dim "Weiss [%d %%]" [ switch="1/0/221", position="13/0/221", increaseDecrease="2/0/221" ]
Type dimmer : Light_EG_Wohnzimmer_Red "Rot [%d %%]" [ switch="1/0/222", position="13/0/222", increaseDecrease="2/0/222" ]
Type dimmer : Light_EG_Wohnzimmer_Green "Grün [%d %%]" [ switch="1/0/223", position="13/0/223", increaseDecrease="2/0/223" ]
Type dimmer : Light_EG_Wohnzimmer_Blue "Blau [%d %%]" [ switch="1/0/224", position="13/0/224", increaseDecrease="2/0/224" ]
Type dimmer : Light_EG_Wohnzimmer_Decke "Esszimmer [%d %%]" [ switch="1/0/220", position="13/0/220", increaseDecrease="2/0/220" ]
Type dimmer : Light_EG_Wohnzimmer_Tisch "Esszimmer Tisch [%d %%]" [ switch="1/0/226", position="13/0/226", increaseDecrease="2/0/225" ]
Type dimmer : Light_OG_Emelie_Decke_Dim "Dimmer Emelie [%d %%]" [ switch="1/0/114", position="13/0/114", increaseDecrease="2/0/114" ]
Type dimmer : Light_OG_Jonathan_Decke_Dim "Dimmer Jonathan [%d %%]" [ switch="1/0/104", position="13/0/104", increaseDecrease="2/0/104" ]
Type rollershutter : Shutter_EG_GaesteWc "Rolladen EG WC [%d %%]" [ upDown="3/0/245", stopMove="4/0/245", position="6/0/245" ]
Type rollershutter : Shutter_EG_Kueche "Rolladen EG Küche[%d %%]" [ upDown="3/0/255", stopMove="4/0/255", position="6/0/255" ]
Type rollershutter : Shutter_EG_Wohnzimmer_Fenster "Rolladen EG Wohnzimmer Fenster[%d %%]" [ upDown="3/0/226", stopMove="4/0/226", position="6/0/226" ]
Type rollershutter : Shutter_EG_Wohnzimmer_Terasse "Rolladen EG Wohnzimmer Terasse[%d %%]" [ upDown="3/0/225", stopMove="4/0/225", position="6/0/225" ]
Type rollershutter : Shutter_OG_Schlafzimmer "Rolladen OG Schlafzimmer[%d %%]" [ upDown="3/0/129", stopMove="4/0/129", position="6/0/129" ]
Type rollershutter : Shutter_OG_Bad "Rolladen OG Bad [%d %%]" [ upDown="3/0/139", stopMove="4/0/239", position="6/0/139" ]
Type rollershutter : Shutter_OG_Emelie "Rolladen OG Emelie[%d %%]" [ upDown="3/0/119", stopMove="4/0/119", position="6/0/119" ]
Type rollershutter : Shutter_OG_Jonathan "Rolladen OG Jonathan [%d %%]" [ upDown="3/0/109", stopMove="4/0/109", position="6/0/109" ]
Type contact : Door_EG_Eingangstuer "Eingangstür [MAP(de.map):%s]" [ ga="11/0/1" ]
Type contact : Door_EG_WC "WC Tür [MAP(de.map):%s]" [ ga="11/0/6" ]
Type contact : Door_EG_Terassentuer "Terassentür [MAP(en.map):%s]" [ ga="11/0/3" ]
Type contact : Door_OG_Badzimmertuer "Badezimmertuer [MAP(de.map):%s]" [ ga="11/0/4" ]
Type contact : Window_EG_Kueche "Fenster Küche [MAP(en.map):%s]" [ ga="11/0/2" ]
Type contact : Window_EG_Wohnzimmer "Fenster Wohnzimmer [MAP(en.map):%s]" [ ga="11/0/0" ]
Type contact : Window_EG_GaesteWc "Fenster Gäste WC [MAP(en.map):%s]" [ ga="11/0/5" ]
Type contact : Window_OG_Bad "Fenster OG Bad [MAP(en.map):%s]" [ ga="11/0/8" ]
Type contact : Window_OG_Schlafzimmer "Fenster OG Schlafzimmer [MAP(en.map):%s]" [ ga="11/0/9" ]
Type contact : Window_OG_Emelie_Window "Fenster Emelie [MAP(en.map):%s]" [ ga="11/0/10" ]
Type contact : Window_OG_Jonathan_Window "Fenster Jonathan [MAP(en.map):%s]" [ ga="11/0/11" ]
Type contact : Heating_EG "Heizung KG/EG [MAP(hz.map):%s]" [ ga="8/0/15" ]
Type contact : Heating_OG "Heizung OG [MAP(hz.map):%s]" [ ga="8/0/16" ]
Type number : Temperatur_EG "Temperatur EG [%.1f °C]" [ ga="8/0/13" ]
Type number : Temperatur_EG_GaesteWc "Temperatur [%.1f °C]" [ ga="8/0/13" ]
Type number : Temperatur_EG_Wohnzimmer "Temperatur [%.1f °C]" [ ga="8/0/13" ]
Type number : Temperatur_EG_Kueche "Temperatur [%.1f °C]" [ ga="8/0/13" ]
Type number : Temperatur_OG "Temperatur OG [%.1f °C]" [ ga="8/0/14" ]
Type number : Temperatur_OG_Emelie "Temperatur [%.1f °C]" [ ga="8/0/14" ]
Type number : Temperatur_OG_Jonathan "Temperatur [%.1f °C]" [ ga="8/0/14" ]
Type number : Temperatur_OG_Bett "Temperatur [%.1f °C]" [ ga="8/0/14" ]
Type number : Solltemp_KG "Solltemperatur KG [%.1f °C]" [ ga="8/0/12" ]
Type number : Solltemp_EG "Solltemperatur EG [%.1f °C]" [ ga="8/0/12" ]
Type number : Solltemp_OG "Solltemperatur OG [%.1f °C]" [ ga="8/0/11" ]
knx.items
Switch Light_KG_Flur_Decke "Flur Keller Decke [%s]" <light> (KG_Flur,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Flur_Decke" }
Switch Light_KG_Buero_Decke "Buerolicht [%s]" <light> (KG_Buero,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Buero_Decke" }
Switch Light_KG_Waschkeller_Decke "Waschkeller" <light> (KG_Waschkueche,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Waschkeller_Decke" }
Switch Light_KG_Regal_Decke "Regal" <light> (KG_Regal,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Regal_Decke" }
Switch Light_KG_Vorrat_Decke "Vorrat" <light> (KG_Vorrat,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Vorrat_Decke" }
Switch Light_EG_Wohnzimmer_White "Wohnzimmerlicht" <light> (EG_Wohnzimmer,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_White" }
Switch Light_EG_Esszimmer "Esszimmerlicht" <light> (EG_Wohnzimmer,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Esszimmer" }
Switch Light_EG_Esszimmer_Tisch "Esszimmer Tisch" <light> (EG_Wohnzimmer,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Esszimmer_Tisch" }
Switch Light_EG_Wohnzimmer_Rainbow "Regenbogen" <light> (EG_Wohnzimmer,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Rainbow" }
Switch Light_EG_Terasse_Mauer "Gartenbeleuchtung" <light> (EG_Terasse,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Terasse_Mauer" }
Switch Light_EG_Terasse_Markise "Lichterkette" <light> (EG_Terasse,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Terasse_Markise" }
Switch Light_EG_Kueche_Decke "Kueche Arbeitsplatte" <light> (EG_Kueche,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Kueche_Decke" }
Switch Light_EG_Kueche_Table "Kueche Tisch" <light> (EG_Kueche,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Kueche_Table" }
Switch Light_EG_Flur_Garderobe "EG Flur" <light> (EG_Flur,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_Flur_Garderobe" }
Switch Light_EG_GaesteWc_Decke "EG GasteWc" <light> (EG_GaesteWc,AlleLichter) { channel="knx:device:bridge:generic:Light_EG_GaesteWc_Decke" }
Switch Light_EG_Tueroeffner "Tueroeffner" (EG_Tueroeffner) { channel="knx:device:bridge:generic:Light_EG_Tueroeffner" }
Switch Light_EG_Haustuer_auf "Haustuer auf" (EG_Tueroeffner) { channel="knx:device:bridge:generic:Light_EG_Haustuer_auf" }
Switch Light_OG_Bad_Decke "OG Badezimmer" <light> (OG_Bad,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Bad_Decke" }
Switch Light_OG_Flur_Decke "OG Flur" <light> (OG_Flur,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Flur_Decke" }
Switch Light_OG_Emelie_Decke "OG Licht Emelie" <light> (OG_Emelie,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Emelie_Decke" }
Switch Light_OG_Jonathan_Decke "Licht" <light> (OG_Jonathan,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Jonathan_Decke" }
Switch Light_OG_Schlafzimmer_Decke "Schlafzimmer" <light> (OG_Schlafzimmer,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Schlafzimmer_Decke" }
Switch Light_Hoflicht "Hoflicht Eingang" <light> (EG_Flur) { channel="knx:device:bridge:generic:Light_Hoflicht" }
Switch Nachabschaltung_Jonathan "Nachtabschaltung Jonathan" <light> (OG_Schlafzimmer, OG_Jonathan) { channel="knx:device:bridge:generic:Nachabschaltung_Jonathan" }
Switch Nachabschaltung_Emelie "Nachtabschaltung Emelie" <light> (OG_Schlafzimmer, OG_Emelie) { channel="knx:device:bridge:generic:Nachabschaltung_Emelie" }
Switch Nachabschaltung_Schlafzimme "Nachtabschaltung Schlafzimmer" <light> (OG_Schlafzimmer) { channel="knx:device:bridge:generic:Nachabschaltung_Schlafzimme" }
Switch Shutter_EG_Wohnzimmer_Markise "Markise" (EG_Terasse, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Markise" }
Switch Shutter_EG_Wohnzimmer_Markise1 "Markise 50%" (EG_Terasse, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Markise1" }
Switch Leinwand_Oben "Rolladen EG Wohnzimmer Leinwand oben" { channel="knx:device:bridge:generic:Leinwand_Oben" }
Switch Leinwand_Unten "Rolladen EG Wohnzimmer Leinwand unten" { channel="knx:device:bridge:generic:Leinwand_Unten" }
Switch Bewegung_KG_Treppe "Bewegungsmelder KG Treppe [%s]" { channel="knx:device:bridge:generic:Bewegung_KG_Treppe" }
Switch Bewegung_EG_Flur "Bewegungsmelder EG Flur [%s]" { channel="knx:device:bridge:generic:Bewegung_EG_Flur" }
Switch Bewegung_OG_Flur "Bewegungsmelder OG Flur [%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Flur" }
Switch Bewegung_EG_WC "Bewegungsmelder EG WC [%s]" { channel="knx:device:bridge:generic:Bewegung_EG_WC" }
Switch Bewegung_OG_Bad "Bewegungsmelder OG Bad [%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Bad" }
Switch Bewegung_OG_Bad_Dusche "Bewegungsmelder OG Bad Dusche [%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Bad_Dusche" }
Switch Bewegung_KG_Buero "Bewegungsmelder KG Buero [%s]" { channel="knx:device:bridge:generic:Bewegung_KG_Buero" }
Switch Alarm_Drainage "Alarm Drainagepumpe defekt" (Status) { channel="knx:device:bridge:generic:Alarm_Drainage" }
Switch Nachtabsenkung "Heizung Nachtabsenkung" (Status) { channel="knx:device:bridge:generic:Nachtabsenkung" }
Switch Komforttemperatur "Komfortemperatur" (Status) { channel="knx:device:bridge:generic:Komforttemperatur" }
Switch WW_Zirkulation "Warmwasser Zirkulation" (Status) { channel="knx:device:bridge:generic:WW_Zirkulation" }
Switch Helligkeit1 "Dach Helligkeitswert 1 Licht" (Status) { channel="knx:device:bridge:generic:Helligkeit1" }
Switch Helligkeit2 "Dach Helligkeitswert 2 Licht" (Status) { channel="knx:device:bridge:generic:Helligkeit2" }
Switch HelligkeitRollo "Dach Helligkeitswert Rollo" (Status) { channel="knx:device:bridge:generic:HelligkeitRollo" }
Dimmer Light_EG_Wohnzimmer_White_dim "Weiss [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_White_dim" }
Dimmer Light_EG_Wohnzimmer_Red "Rot [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Red" }
Dimmer Light_EG_Wohnzimmer_Green "Grün [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Green" }
Dimmer Light_EG_Wohnzimmer_Blue "Blau [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Blue" }
Dimmer Light_EG_Wohnzimmer_Decke "Esszimmer [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Decke" }
Dimmer Light_EG_Wohnzimmer_Tisch "Esszimmer Tisch [%d %%]" (EG_Wohnzimmer) { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Tisch" }
Dimmer Light_OG_Emelie_Decke_Dim "Dimmer Emelie [%d %%]" (OG_Emelie) { channel="knx:device:bridge:generic:Light_OG_Emelie_Decke_Dim" }
Dimmer Light_OG_Jonathan_Decke_Dim "Dimmer Jonathan [%d %%]" (OG_Jonathan) { channel="knx:device:bridge:generic:Light_OG_Jonathan_Decke_Dim" }
Rollershutter Shutter_EG_GaesteWc "Rolladen EG WC [%d %%]" (EG_GaesteWc, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_GaesteWc" }
Rollershutter Shutter_EG_Kueche "Rolladen EG Küche[%d %%]" (EG_Kueche, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_Kueche" }
Rollershutter Shutter_EG_Wohnzimmer_Fenster "Rolladen EG Wohnzimmer Fenster[%d %%]" (EG_Wohnzimmer, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Fenster" }
Rollershutter Shutter_EG_Wohnzimmer_Terasse "Rolladen EG Wohnzimmer Terasse[%d %%]" (EG_Wohnzimmer, Rollaeden) { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Terasse" }
Rollershutter Shutter_OG_Schlafzimmer "Rolladen OG Schlafzimmer[%d %%]" (OG_Schlafzimmer, Rollaeden) { channel="knx:device:bridge:generic:Shutter_OG_Schlafzimmer" }
Rollershutter Shutter_OG_Bad "Rolladen OG Bad [%d %%]" (OG_Bad, Rollaeden) { channel="knx:device:bridge:generic:Shutter_OG_Bad" }
Rollershutter Shutter_OG_Emelie "Rolladen OG Emelie[%d %%]" (OG_Emelie, Rollaeden) { channel="knx:device:bridge:generic:Shutter_OG_Emelie" }
Rollershutter Shutter_OG_Jonathan "Rolladen [%d %%]" (OG_Jonathan, Rollaeden) { channel="knx:device:bridge:generic:Shutter_OG_Jonathan" }
Contact Door_EG_Eingangstuer "Eingangstür [MAP(de.map):%s]" <door> (EG_Flur, Doors) { channel="knx:device:bridge:generic:Door_EG_Eingangstuer" }
Contact Door_EG_WC "WC Tür [MAP(de.map):%s]" <door> (EG_GaesteWc, Doors) { channel="knx:device:bridge:generic:Door_EG_WC" }
Contact Door_EG_Terassentuer "Terassentür [MAP(en.map):%s]" <door> (EG_Wohnzimmer, Windows) { channel="knx:device:bridge:generic:Door_EG_Terassentuer" }
Contact Door_OG_Badzimmertuer "Badezimmertuer [MAP(de.map):%s]" <door> (OG_Bad, Doors) { channel="knx:device:bridge:generic:Door_OG_Badzimmertuer" }
Contact Window_EG_Kueche "Fenster Küche [MAP(en.map):%s]" (EG_Kueche, Windows) { channel="knx:device:bridge:generic:Window_EG_Kueche" }
Contact Window_EG_Wohnzimmer "Fenster Wohnzimmer [MAP(en.map):%s]" (EG_Wohnzimmer, Windows) { channel="knx:device:bridge:generic:Window_EG_Wohnzimmer" }
Contact Window_EG_GaesteWc "Fenster Gäste WC [MAP(en.map):%s]" (EG_GaesteWc, Windows) { channel="knx:device:bridge:generic:Window_EG_GaesteWc" }
Contact Window_OG_Bad "Fenster OG Bad [MAP(en.map):%s]" (OG_Bad, Windows) { channel="knx:device:bridge:generic:Window_OG_Bad" }
Contact Window_OG_Schlafzimmer "Fenster OG Schlafzimmer [MAP(en.map):%s]" (OG_Schlafzimmer, Windows) { channel="knx:device:bridge:generic:Window_OG_Schlafzimmer" }
Contact Window_OG_Emelie_Window "Fenster Emelie [MAP(en.map):%s]" (OG_Emelie, Windows) { channel="knx:device:bridge:generic:Window_OG_Emelie_Window" }
Contact Window_OG_Jonathan_Window "Fenster Jonathan [MAP(en.map):%s]" (OG_Jonathan, Windows) { channel="knx:device:bridge:generic:Window_OG_Jonathan_Window" }
Contact Heating_EG "Heizung KG/EG [MAP(hz.map):%s]" <heating> (EG, Heating) { channel="knx:device:bridge:generic:Heating_EG" }
Contact Heating_OG "Heizung OG [MAP(hz.map):%s]" <heating> (OG, Heating) { channel="knx:device:bridge:generic:Heating_OG" }
Number Temperatur_EG "Temperatur EG [%.1f °C]" <temperature> (Temperatur, EG_Flur) { channel="knx:device:bridge:generic:Temperatur_EG" }
Number Temperatur_EG_GaesteWc "Temperatur [%.1f °C]" <temperature> (Temperatur, EG_GaesteWc) { channel="knx:device:bridge:generic:Temperatur_EG_GaesteWc" }
Number Temperatur_EG_Wohnzimmer "Temperatur [%.1f °C]" <temperature> (Temperatur, EG_Wohnzimmer) { channel="knx:device:bridge:generic:Temperatur_EG_Wohnzimmer" }
Number Temperatur_EG_Kueche "Temperatur [%.1f °C]" <temperature> (Temperatur, EG_Kueche) { channel="knx:device:bridge:generic:Temperatur_EG_Kueche" }
Number Temperatur_OG "Temperatur OG [%.1f °C]" <temperature> (Temperatur, OG_Bad) { channel="knx:device:bridge:generic:Temperatur_OG" }
Number Temperatur_OG_Emelie "Temperatur [%.1f °C]" <temperature> (Temperatur, OG_Emelie) { channel="knx:device:bridge:generic:Temperatur_OG_Emelie" }
Number Temperatur_OG_Jonathan "Temperatur [%.1f °C]" <temperature> (Temperatur, OG_Jonathan) { channel="knx:device:bridge:generic:Temperatur_OG_Jonathan" }
Number Temperatur_OG_Bett "Temperatur [%.1f °C]" <temperature> (Temperatur, OG_Bett) { channel="knx:device:bridge:generic:Temperatur_OG_Bett" }
Number Solltemp_KG "Solltemperatur KG [%.1f °C]" <temperature> (Temperatur, KG, KG_Buero) { channel="knx:device:bridge:generic:Solltemp_KG" }
Number Solltemp_EG "Solltemperatur EG [%.1f °C]" <temperature> (Temperatur, EG) { channel="knx:device:bridge:generic:Solltemp_EG" }
Number Solltemp_OG "Solltemperatur OG [%.1f °C]" <temperature> (Temperatur, OG) { channel="knx:device:bridge:generic:Solltemp_OG" }
