Dim,
thanks for the quick reply.
Success! Now everything is working fine and the OH UI is updated based on events on the KNX
I do not really know what I did to fix it. In fact following your suggestions I did the following:
- the Gira router (1/1/0) was already configured to “route” the telegram as suggested in your previous post and therefore I did not change anything.
- Also, as you suggested in your previous post, I already created a dummy app on line 1.2 (address 1/2/200).
- I added “timeout=10000” in the knx.cfg file (anyway since timout=10000 is the default value, it should not really matter).
- I deleted file /var/lib/openhab2/config/org/openhab/knx.config. Maybe this file was the problem??
- I restarted OH2.
- This is the content of /var/lib/openhab2/config/org/openhab/knx.config:
busaddr="1.2.200"
ignorelocalevents="true"
ip="224.0.23.12"
service.pid="org.openhab.knx"
timeout="10000"
type=“ROUTER”
Now everthing is update: swithced temperatures, etc.
This is the new log after restarting OH2 service.
2017-12-31 15:19:05.845 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-12-31 15:19:16.344 [INFO ] [nx.internal.connection.KNXConnection] - Closing KNX connection
2017-12-31 15:19:16.452 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-12-31 15:19:16.480 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = d5040466-81d9-4c67-b129-************, base URL = http://localhost:8080)
2017-12-31 15:19:16.592 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been shut down
2017-12-31 15:19:16.751 [.event.RuleStatusInfoEvent] - 908b4416-b756-47f9-ab02-c78759a51f7b updated: UNINITIALIZED (HANDLER_MISSING_ERROR): Missing handlers: jsr223.ScriptedAction
2017-12-31 15:19:16.764 [ome.event.RuleRemovedEvent] - Rule ‘908b4416-b756-47f9-ab02-c78759a51f7b’ has been removed.
2017-12-31 15:19:17.359 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-12-31 15:19:17.393 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-12-31 15:19:30.450 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
2017-12-31 15:19:34.111 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = d5040466-81d9-4c67-b129-************, base URL = http://localhost:8080)
2017-12-31 15:19:42.179 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.items’
2017-12-31 15:19:43.286 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
2017-12-31 15:19:43.314 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘logging.persist’
2017-12-31 15:19:48.408 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.rules’
2017-12-31 15:19:49.387 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2017-12-31 15:19:49.688 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.script’
2017-12-31 15:19:50.315 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.sitemap’
2017-12-31 15:19:50.685 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.things’
2017-12-31 15:19:50.693 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘demo.things’ is either empty or cannot be parsed correctly!
2017-12-31 15:19:52.189 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.195:8080
2017-12-31 15:19:52.213 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.195:8443
2017-12-31 15:19:52.884 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2017-12-31 15:19:53.348 [GroupItemStateChangedEvent] - Heating changed from NULL to ON through Heating_General_FloorPanels
2017-12-31 15:19:53.352 [GroupItemStateChangedEvent] - General changed from NULL to ON through Heating_General_FloorPanels
2017-12-31 15:19:53.358 [vent.ItemStateChangedEvent] - Heating_General_FloorPanels changed from NULL to ON
2017-12-31 15:19:53.366 [vent.ItemStateChangedEvent] - Heating_Bedroom_Bathroom changed from NULL to OFF
2017-12-31 15:19:53.375 [vent.ItemStateChangedEvent] - Heating_Outside_GarageRamp changed from NULL to OFF
2017-12-31 15:19:53.380 [vent.ItemStateChangedEvent] - Heating_General_WaterRecycle changed from NULL to ON
2017-12-31 15:19:53.393 [vent.ItemStateChangedEvent] - Heating_Bedroom_Bedroom changed from NULL to OFF
2017-12-31 15:19:53.398 [vent.ItemStateChangedEvent] - Heating_General_Radiators changed from NULL to OFF
2017-12-31 15:19:53.402 [vent.ItemStateChangedEvent] - Heating_Bedroom_BathroomOverride changed from NULL to OFF
2017-12-31 15:19:54.407 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-12-31 15:19:54.515 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-12-31 15:19:55.006 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2017-12-31 15:19:55.028 [INFO ] [ulation.internal.HueEmulationServlet] - Started Hue Emulation service at /api
2017-12-31 15:19:55.355 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘hue:bridge:0017880ae670’ to inbox.
2017-12-31 15:19:55.468 [ome.event.ItemCommandEvent] - Item ‘Temperature_Bedroom_Bedroom’ received command 24.96
2017-12-31 15:19:55.472 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Rain’ received command OFF
2017-12-31 15:19:55.492 [home.event.InboxAddedEvent] - Discovery Result with UID ‘hue:bridge:0017880ae670’ has been added.
2017-12-31 15:19:55.511 [vent.ItemStateChangedEvent] - Temperature_Bedroom_Bedroom changed from NULL to 24.96
2017-12-31 15:19:55.518 [GroupItemStateChangedEvent] - Temperature changed from NULL to 24.96 through Temperature_Bedroom_Bedroom
2017-12-31 15:19:55.525 [GroupItemStateChangedEvent] - Temperature changed from 24.96 to 12.48 through Sensor_Outside_Rain
2017-12-31 15:19:55.529 [vent.ItemStateChangedEvent] - Sensor_Outside_Rain changed from NULL to OFF
2017-12-31 15:19:55.533 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Rain’ received command OFF
2017-12-31 15:19:55.595 [INFO ] [rt.internal.loader.ScriptFileWatcher] - Loading script ‘demo.js’
2017-12-31 15:19:55.731 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Services_Kitchen’ received command 23.0
2017-12-31 15:19:55.756 [vent.ItemStateChangedEvent] - Setpoint_Services_Kitchen changed from NULL to 23.0
2017-12-31 15:19:55.758 [GroupItemStateChangedEvent] - Temperature changed from 12.48 to 15.99 through Setpoint_Services_Kitchen
2017-12-31 15:19:55.952 [ome.event.ItemCommandEvent] - Item ‘Temperature_Living_Living’ received command 25.240000000000002
2017-12-31 15:19:55.960 [vent.ItemStateChangedEvent] - Temperature_Living_Living changed from NULL to 25.240000000000002
2017-12-31 15:19:55.963 [GroupItemStateChangedEvent] - Temperature changed from 15.99 to 18.300000000000001 through Temperature_Living_Living
2017-12-31 15:19:56.182 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Guests_Bedroom3’ received command 18.0
2017-12-31 15:19:56.189 [vent.ItemStateChangedEvent] - Setpoint_Guests_Bedroom3 changed from NULL to 18.0
2017-12-31 15:19:56.195 [GroupItemStateChangedEvent] - Temperature changed from 18.300000000000001 to 18.240000000000000 through Setpoint_Guests_Bedroom3
2017-12-31 15:19:56.403 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Bedroom_Bedroom’ received command 24.0
2017-12-31 15:19:56.409 [vent.ItemStateChangedEvent] - Setpoint_Bedroom_Bedroom changed from NULL to 24.0
2017-12-31 15:19:56.413 [GroupItemStateChangedEvent] - Temperature changed from 18.240000000000000 to 19.200000000000000 through Setpoint_Bedroom_Bedroom
2017-12-31 15:19:56.635 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Living_Office’ received command 22.5
2017-12-31 15:19:56.647 [vent.ItemStateChangedEvent] - Setpoint_Living_Office changed from NULL to 22.5
2017-12-31 15:19:56.650 [GroupItemStateChangedEvent] - Temperature changed from 19.200000000000000 to 19.671428571428572 through Setpoint_Living_Office
2017-12-31 15:19:56.854 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Guests_Bedroom2’ received command 18.0
2017-12-31 15:19:56.862 [vent.ItemStateChangedEvent] - Setpoint_Guests_Bedroom2 changed from NULL to 18.0
2017-12-31 15:19:56.865 [GroupItemStateChangedEvent] - Temperature changed from 19.671428571428572 to 19.462500000000000 through Setpoint_Guests_Bedroom2
2017-12-31 15:19:57.082 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Apartment_Apartment’ received command 21.7
2017-12-31 15:19:57.087 [vent.ItemStateChangedEvent] - Setpoint_Apartment_Apartment changed from NULL to 21.7
2017-12-31 15:19:57.090 [GroupItemStateChangedEvent] - Temperature changed from 19.462500000000000 to 19.711111111111111 through Setpoint_Apartment_Apartment
2017-12-31 15:19:57.310 [ome.event.ItemCommandEvent] - Item ‘Temperature_Services_Kitchen’ received command 21.240000000000002
2017-12-31 15:19:57.319 [vent.ItemStateChangedEvent] - Temperature_Services_Kitchen changed from NULL to 21.240000000000002
2017-12-31 15:19:57.325 [GroupItemStateChangedEvent] - Temperature changed from 19.711111111111111 to 19.864000000000000 through Temperature_Services_Kitchen
2017-12-31 15:19:57.468 [ome.event.ItemCommandEvent] - Item ‘Temperature_Outside_Outside’ received command 6.1000000000000005
2017-12-31 15:19:57.475 [vent.ItemStateChangedEvent] - Temperature_Outside_Outside changed from NULL to 6.1000000000000005
2017-12-31 15:19:57.478 [GroupItemStateChangedEvent] - Temperature changed from 19.864000000000000 to 18.6127272727272731 through Temperature_Outside_Outside
2017-12-31 15:19:57.580 [ome.event.ItemCommandEvent] - Item ‘Temperature_Outside_Outside’ received command 6.1000000000000005
2017-12-31 15:19:57.604 [ome.event.ItemCommandEvent] - Item ‘Temperature_Outside_Outside’ received command 6.1000000000000005
2017-12-31 15:19:57.691 [ome.event.ItemCommandEvent] - Item ‘Temperature_Apartment_Apartment’ received command 21.5
2017-12-31 15:19:57.697 [vent.ItemStateChangedEvent] - Temperature_Apartment_Apartment changed from NULL to 21.5
2017-12-31 15:19:57.698 [GroupItemStateChangedEvent] - Temperature changed from 18.6127272727272731 to 18.8533333333333337 through Temperature_Apartment_Apartment
2017-12-31 15:19:57.912 [ome.event.ItemCommandEvent] - Item ‘Temperature_Living_Office’ received command 22.5
2017-12-31 15:19:57.925 [GroupItemStateChangedEvent] - Temperature changed from 18.8533333333333337 to 19.1338461538461542 through Temperature_Living_Office
2017-12-31 15:19:57.943 [vent.ItemStateChangedEvent] - Temperature_Living_Office changed from NULL to 22.5
2017-12-31 15:19:58.202 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Services_Laundry’ received command 22.0
2017-12-31 15:19:58.207 [vent.ItemStateChangedEvent] - Setpoint_Services_Laundry changed from NULL to 22.0
2017-12-31 15:19:58.210 [GroupItemStateChangedEvent] - Temperature changed from 19.1338461538461542 to 19.3385714285714289 through Setpoint_Services_Laundry
2017-12-31 15:19:58.366 [vent.ItemStateChangedEvent] - Light_Living_Walkway changed from NULL to OFF
2017-12-31 15:19:58.369 [GroupItemStateChangedEvent] - Lights changed from NULL to OFF through Light_Living_Walkway
2017-12-31 15:19:58.591 [ome.event.ItemCommandEvent] - Item ‘Temperature_Guests_Attic’ received command 17.6
2017-12-31 15:19:58.594 [vent.ItemStateChangedEvent] - Temperature_Guests_Attic changed from NULL to 17.6
2017-12-31 15:19:58.596 [GroupItemStateChangedEvent] - Temperature changed from 19.3385714285714289 to 19.2226666666666670 through Temperature_Guests_Attic
2017-12-31 15:19:58.813 [ome.event.ItemCommandEvent] - Item ‘Temperature_Guests_Bedroom3’ received command 19.76
2017-12-31 15:19:58.819 [vent.ItemStateChangedEvent] - Temperature_Guests_Bedroom3 changed from NULL to 19.76
2017-12-31 15:19:58.822 [GroupItemStateChangedEvent] - Temperature changed from 19.2226666666666670 to 19.2562500000000003 through Temperature_Guests_Bedroom3
2017-12-31 15:19:59.041 [ome.event.ItemCommandEvent] - Item ‘Temperature_Services_Laundry’ received command 23.14
2017-12-31 15:19:59.060 [GroupItemStateChangedEvent] - Temperature changed from 19.2562500000000003 to 19.4847058823529414 through Temperature_Services_Laundry
2017-12-31 15:19:59.062 [vent.ItemStateChangedEvent] - Temperature_Services_Laundry changed from NULL to 23.14
2017-12-31 15:19:59.264 [ome.event.ItemCommandEvent] - Item ‘Temperature_Guests_Bedroom2’ received command 21.68
2017-12-31 15:19:59.272 [vent.ItemStateChangedEvent] - Temperature_Guests_Bedroom2 changed from NULL to 21.68
2017-12-31 15:19:59.275 [GroupItemStateChangedEvent] - Temperature changed from 19.4847058823529414 to 19.6066666666666669 through Temperature_Guests_Bedroom2
2017-12-31 15:19:59.434 [ome.event.ItemCommandEvent] - Item ‘Shutter_Apartment_Bedroom’ received command STOP
2017-12-31 15:19:59.436 [thome.event.RuleAddedEvent] - Rule ‘dbd1e7c5-9eed-4a31-a49e-9944321be119’ has been added.
2017-12-31 15:19:59.445 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: INITIALIZING
2017-12-31 15:19:59.484 [ome.event.ItemCommandEvent] - Item ‘Shutter_Apartment_Bedroom’ received command STOP
2017-12-31 15:19:59.535 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: IDLE
2017-12-31 15:19:59.662 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Services_Mudroom’ received command 21.0
2017-12-31 15:19:59.667 [vent.ItemStateChangedEvent] - Setpoint_Services_Mudroom changed from NULL to 21.0
2017-12-31 15:19:59.670 [GroupItemStateChangedEvent] - Temperature changed from 19.6066666666666669 to 19.6800000000000002 through Setpoint_Services_Mudroom
2017-12-31 15:19:59.956 [ome.event.ItemCommandEvent] - Item ‘Temperature_Services_Mudroom’ received command 21.36
2017-12-31 15:19:59.968 [vent.ItemStateChangedEvent] - Temperature_Services_Mudroom changed from NULL to 21.36
2017-12-31 15:19:59.971 [GroupItemStateChangedEvent] - Temperature changed from 19.6800000000000002 to 19.7640000000000002 through Temperature_Services_Mudroom
2017-12-31 15:20:00.099 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Brightness’ received command 1537.28
2017-12-31 15:20:00.102 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: RUNNING
2017-12-31 15:20:00.111 [vent.ItemStateChangedEvent] - Sensor_Outside_Brightness changed from NULL to 1537.28
2017-12-31 15:20:00.117 [GroupItemStateChangedEvent] - Temperature changed from 19.7640000000000002 to 92.0266666666666669 through Sensor_Outside_Brightness
2017-12-31 15:20:00.137 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: IDLE
2017-12-31 15:20:00.194 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Brightness’ received command 1537.28
2017-12-31 15:20:00.218 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Wind’ received command 0.0
2017-12-31 15:20:00.224 [vent.ItemStateChangedEvent] - Sensor_Outside_Wind changed from NULL to 0.0
2017-12-31 15:20:00.227 [GroupItemStateChangedEvent] - Temperature changed from 92.0266666666666669 to 87.8436363636363638 through Sensor_Outside_Wind
2017-12-31 15:20:00.444 [ome.event.ItemCommandEvent] - Item ‘Setpoint_Guests_Attic’ received command 17.0
2017-12-31 15:20:00.451 [vent.ItemStateChangedEvent] - Setpoint_Guests_Attic changed from NULL to 17.0
2017-12-31 15:20:00.455 [GroupItemStateChangedEvent] - Temperature changed from 87.8436363636363638 to 84.7634782608695654 through Setpoint_Guests_Attic
2017-12-31 15:20:15.948 [ome.event.ItemCommandEvent] - Item ‘Sensor_Outside_Brightness’ received command 1692.16
2017-12-31 15:20:15.955 [vent.ItemStateChangedEvent] - Sensor_Outside_Brightness changed from 1537.28 to 1692.16
2017-12-31 15:20:15.958 [GroupItemStateChangedEvent] - Temperature changed from 84.7634782608695654 to 91.4973913043478263 through Sensor_Outside_Brightness
2017-12-31 15:20:27.035 [ome.event.ItemCommandEvent] - Item ‘Temperature_Services_Mudroom’ received command 21.5
2017-12-31 15:20:27.045 [vent.ItemStateChangedEvent] - Temperature_Services_Mudroom changed from 21.36 to 21.5
2017-12-31 15:20:27.048 [GroupItemStateChangedEvent] - Temperature changed from 91.4973913043478263 to 91.5034782608695654 through Temperature_Services_Mudroom
2017-12-31 15:21:00.159 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: RUNNING
2017-12-31 15:21:00.162 [.event.RuleStatusInfoEvent] - dbd1e7c5-9eed-4a31-a49e-9944321be119 updated: IDLE
2017-12-31 15:21:17.001 [ome.event.ItemCommandEvent] - Item ‘Temperature_Bedroom_Bedroom’ received command 25.26
2017-12-31 15:21:17.008 [vent.ItemStateChangedEvent] - Temperature_Bedroom_Bedroom changed from 24.96 to 25.26
2017-12-31 15:21:17.014 [GroupItemStateChangedEvent] - Temperature changed from 91.5034782608695654 to 91.5165217391304350 through Temperature_Bedroom_Bedroom
Thanks so much,
Alex
