Hello there!
It’s been quite a while since my last visit (got a 3 month old toddler now ) but now i can find some time for my hobby again.
I set up a test setup for KNX to get used to it before considering using KNX for all kinds of applications.
The setup in the ETS 5 works so far and i am able to control a switch-actor with a push button (which is fine for the first steps).
My target is to control the actor with a simple sitemap.
Unfortunately I am doing something wrong.
There are no obvious log entries (typo or anything).
In the KNX environment i have to use NAT mode or the interface (IPS 200 REG Jung) won’t connect.
Anyway I tried it with tunneling true and without but the actor won’t trigger.
Hope you can help.
Here are my files:
Things:
Bridge knx:ip:bridge [
ipAddress="192.168.178.40",
portNumber=3671,
//localIp="192.168.178.11",
//type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1
//localSourceAddr="0.0.0",
//useNAT=true
Thing device generic {
Type switch-control : AnlageKNX "Anlage KNX" [ ga="1/1/1" ]
Items:
Switch Testbutton "Light [%s]" <light> { channel="knx:device:bridge:generic:AnlageKNX" }
Sitemap:
Switch item=Testbutton label="Testschalter"
KNX Group setup:
