yesterday I migrated from KNX1 to KNX2. I have some coupling between bindings like (KNX binding and squeezbox binding and others …)
The items-File couples the knx binding with the squeezebox binding:
Switch sq_wohnen_power "Wohnzimmer Lautsprecher" { channel="knx:device:bridge:Steckdose:Ch_E", channel="squeezebox:squeezeboxplayer:bebaee7f:wohnen:power" }
KNX-things-File:
Thing device Steckdose "20fach Schaltaktor Steckdosen" [ address="0.1.6", fetch=false, pingInterval=600, readInterval=0 ]
Type switch-control : Ch_E "Verstärker WZ" [ ga="1/5/2+<3/5/2" ]
squeezebox-things-File:
Bridge squeezebox:squeezeboxserver:bebaee7f [ ipAddress="192.168.2.1", webport=9001, cliport=9090 ]
Thing squeezeboxplayer wohnen[ mac="00:04:20:06:21:aa"]
Thing squeezeboxplayer schlafen[ mac="00:04:20:06:21:6d"]
Thing squeezeboxplayer bad[ mac="00:04:20:17:44:8d"]
Thing squeezeboxplayer gaeste[ mac="00:04:20:1e:e7:12"]
which worked with KNX1 fine. When I switched ON my Squeezebox, the corresponding KNX GA switchend ON. When I switched ON the KNX GA, the Squeezebox starts.
With KNX2 this does not work anymore. Is this a bug, a feature or did I miss anything?
I know, that I can solve this with rules, but this would be a mess and in my opinion this binding coupling should work, as this example comes from the docu:
Switch demoSwitch "Light [%s]" <light> { channel="hue:0210:bridge:1:color", channel="knx:device:bridge:generic:controlSwitch" }
Hope anybody can help. Thank you.
BTW: it seems, that couplings with other binding doesn’t work, too
