After the migration to KNX2 binding, I’ve noticed a change in the behavior of the KNX binding.
With the same definition (that might be the issue … ), the object control sent from openHAB to the KNX bus has changed from a 1 byte to a 2 bytes objects.
Previously, in with KNX1, I used the following item definition:
Number regulModeChauffageChambre5 “Mode chauffage chambre 5” {knx=“5.005:4/2/1”}
Number statutModeChauffageChambre5 “Mode chauffage chambre 5 [%d]” {knx="<5.005:4/3/1"}
The heating room Control was correctly updating on the change of “regulModeChauffageChambre5”
Now, in KNX2, I’ve change to this things and the following items:
Type number : regulModeChauffageChambre5 "Mode chauffage chambre 5" [ ga="5.005:4/2/1"] Type number : statutModeChauffageChambre5 "Statut Mode chauffage chambre 5" [ ga="5.005:<4/3/1"]
and the items
Number regulModeChauffageChambre5 “Mode chauffage chambre 5” {channel=“knx:device:MERTEN:HDL_GM6:regulModeChauffageChambre5”}
Number statutModeChauffageChambre5 “Statut Mode chauffage chambre 5 [%d]” {channel=“knx:device:MERTEN:HDL_GM6:statutModeChauffageChambre5”}
Any idea of I’ve missed??
Regards
