Dear,
I have a problem with two blinds (all other in my home is ok).
I have this into my things definition:
Type rollershutter : KNX_APP_TapparellaPortaFinestraCamera "KNX [APP] Tapparella Porta Finestra Camera" [ upDown="1/0/8", stopMove="1/0/9", position="5.001:1/1/9+<1/1/8" ]
Type rollershutter : KNX_APP_TapparellaFinestraCameretta "KNX [APP] Tapparella Finestra Cameretta" [ upDown="1/0/6", stopMove="1/0/7", position="5.001:1/1/7+<1/1/6" ]
When I move the “KNX_APP_TapparellaFinestraCameretta” Item I have not a status change, but if I move the “KNX_APP_TapparellaPortaFinestraCamera” item I have two states updates.
This is the log:
09:05:10.207 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'KNX_APP_TapparellaFinestraCameretta' received command UP
09:05:12.078 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'KNX_APP_TapparellaFinestraCameretta' received command STOP
09:05:23.394 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'KNX_APP_TapparellaPortaFinestraCamera' received command UP
09:05:25.507 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'KNX_APP_TapparellaPortaFinestraCamera' received command STOP
09:05:25.612 [INFO ] [smarthome.event.ItemStateChangedEvent] - KNX_APP_TapparellaPortaFinestraCamera changed from 16 to 7
09:05:25.628 [INFO ] [smarthome.event.ItemStateChangedEvent] - KNX_APP_TapparellaFinestraCameretta changed from 16 to 7
With ETS I tested the values in the groups 1/1//6 and 1/1/8 and the 2 groups have two different values because the blinds are in different position after the stop and this is correct, but I don’t understand because in OH the two states have always the same values for my 2 groups linked to only one item movement.
Can you help me please?
Fausto
