after my raspberry pi crashed and burned, I had to recover and reconfigure everything which got destroyed. After recovery i also started with the migration from onewire1 and knx1 to the version2 variants. I must first admit, that I switched yesterday to snapshot for one OneWire2 feature and stayed there after everything worked with my knx1 configuration.
It took me quiet a while to accept the abstraction from items to items and things. Now I like this documentations feeling of it and optimizing small things on ETS as well. I had no problems with Switches, Contacts, Sensors (Lux, kWh, Wh, Windows, Percentage, …). But now I was sitting for a couple of hours on my Heating SetPoints for my Rooms. Nothing worked.
I just figured out, that UoM seems to be the problem. The Workflow seems to be:
- Thing: Data received as a float
- Item: Data converted to UoM Value
- User: Uses SetPoint to increase the Value on the Item
- Item: Sends Data to the Thing
- Thing: Evaluates the UoM and realises the KNX GA can’t work with the String “20 °C”
- [User: Can’t figure out the Problem without enabling the Debug logs]
Error Message I got:
None of the configured GAs on channel ‘knx:device:bridge:heizung-eg:kanal-d-sollwert-komfort’ could handle the command ‘19 °C’ of type ‘QuantityType’)
Item:
Number Temperature_EG_Guest_Setpoint “Gästezimmer [%.1f °C]” <temperature> (gGuestthermostat,Temperature_Setpoint) [ “TargetTemperature” ] {channel=“knx:device:bridge:heizung-eg:kanal-d-sollwert-komfort”}
Type:
Type number : kanal-d-sollwert-komfort “Sollwert Komfort - Gästezimmer” [ ga = “9.001:5/2/42+<5/2/44”]
Everything works as I expect as soon as I remove “°C” from the items configurations (which are there since OpenHAB1.x)
So my Questions is basicly the following:
- What am I missing in the UoM abstraction? or is it just a Snapshot Problem?
- Is there a workaround (except writing a rule for 16 Things/Items)?
- If its not a Snapshot Problem - will there be a conversion in 2.5 (especially since there are default DPTs or custom defined DPTs)?
Best,
Tim
