It seams nobody has problems with this binding canāt find an answer to my problem.
I got my OpenHAB installation to connect to LG TV. I get the message that status changed to connected when I start the OpenHAB. But when I try to use in wiki given example commands to control the TV I get this response for every action:
Have you configured the following lines in your openhab.cfg file, its where you also assign your TV id`s :-
################################## LgTV Binding ######################################
# The ip address of the lgtv
#lgtv:<lgtvId1>.host=
# The TCP port address to use
#lgtv:<lgtvId1>.port=
# The the pairkey / if it's wrong the device shows the right pairkey
# at every connection attempt
#lgtv:<lgtvId1>.pairkey=
# The TCP port address of the openhab system to receive lgtv status messages
# (only first occurance is used for all tvs)
#lgtv:<lgtvId1>.serverport=
# The location to put xml files with the information of availiable
# channels and apps (optional)
#lgtv:<lgtvId1>.xmldatafiles=./
# The check alive interval (optional, defaults to 60secs)
#lgtv:<lgtvId1>.checkalive=
@SupraWez thank you for reply and sorry for the typo not sure how did I managed to post not complete Openhab.cfg cut out. Iām sure you would have spotted the mistake I had but thank you for your example when I saw it I realized where my mistake wasā¦
lgtv:<lgsvetaine>.serverport=8080
