Hey guys, I made a simple rule based on a group switch state on/off to switch on/off my 2 bulbs. This is the rule:
Item AlleLichten changed from OFF to ON
sendCommand(KeukenLamp, ON)
sendCommand(WoonkamerLamp, ON)
rule "Licht uit"
Item AlleLichten changed from ON to OFF
sendCommand(KeukenLamp, OFF)
sendCommand(WoonkamerLamp, OFF)
items file:
Group:Switch:OR(ON, OFF) AlleLichten "Alle lampies" ["Switchable"]
Switch WoonkamerLamp "WoonkamerLamp" (AlleLichten) ["Lighting"] {channel="milight:rgbwwLed:F0FE6B3BD6A2:1:ledbrightness"}
Switch KeukenLamp "KeukenLamp" (AlleLichten) ["Lighting"] {channel="milight:rgbwwLed:F0FE6B3BD6A2:2:ledbrightness"}
Now when I hit the switch in ClassicUI or through Google Assistant, I see the switches hop on and off again rapidly en randomly stops with one light on and one off. When I hit it a few times they all go off or on. These are the logs:
2019-02-28 11:27:48.863 [GroupItemStateChangedEvent] - AlleLichten changed from OFF to ON through KeukenLamp
2019-02-28 11:27:48.871 [vent.ItemStateChangedEvent] - KeukenLamp changed from OFF to ON
2019-02-28 11:27:48.878 [ome.event.ItemCommandEvent] - Item ‘KeukenLamp’ received command OFF
2019-02-28 11:27:48.887 [ome.event.ItemCommandEvent] - Item ‘KeukenLamp’ received command ON
2019-02-28 11:27:48.896 [ome.event.ItemCommandEvent] - Item ‘WoonkamerLamp’ received command ON
2019-02-28 11:27:48.899 [ome.event.ItemCommandEvent] - Item ‘WoonkamerLamp’ received command OFF
2019-02-28 11:27:48.903 [vent.ItemStateChangedEvent] - WoonkamerLamp changed from OFF to ON
2019-02-28 11:27:48.906 [nt.ItemStatePredictedEvent] - KeukenLamp predicted to become OFF
2019-02-28 11:27:48.909 [nt.ItemStatePredictedEvent] - KeukenLamp predicted to become ON
2019-02-28 11:27:48.914 [vent.ItemStateChangedEvent] - KeukenLamp changed from ON to OFF
2019-02-28 11:27:48.917 [nt.ItemStatePredictedEvent] - WoonkamerLamp predicted to become ON
2019-02-28 11:27:48.919 [nt.ItemStatePredictedEvent] - WoonkamerLamp predicted to become OFF
2019-02-28 11:27:48.922 [vent.ItemStateChangedEvent] - KeukenLamp changed from OFF to ON
2019-02-28 11:27:48.924 [vent.ItemStateChangedEvent] - WoonkamerLamp changed from ON to OFF
This is how the UI looks:
