[SOLVED] Lights switch not correctly
Hi All,
I use following simple codes to turn on/off lights periodically
rule "Periodically check auto lights"
    Time cron "0 */10 * ? * *"
	// If nobody is home and dark outside
	if (AlleAusserHaus.state == ON && now.isAfter((Sunset_Time.state as DateTimeType).zonedDateTime.toInstant().toEpochMilli) ||
            now.isBefore((Sunrise_Time.state as DateTimeType).zonedDateTime.toInstant().toEpochMilli)){
		logInfo("LightsAuto", "Auto Light Check")
        gEG_Licht.members.forEach[lamp|
			lamp.sendCommand( lamp.historicState(now.minusDays(7),"rrd4j").state.toString )
         logInfo("myrule","historic state {}",lamp.historicState(now.minusDays(7),"rrd4j").state)
Unfortunately, the lights swtiches even if we are at home or not:
2018-11-06 00:30:00.051 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 00:40:00.055 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 00:50:00.058 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:00:00.049 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:10:00.044 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:20:00.066 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:30:00.071 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:40:00.046 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 01:50:00.053 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:00:00.085 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:10:00.057 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:20:00.079 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:30:00.051 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:40:00.048 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 02:50:00.046 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:00:00.060 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:10:00.057 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:20:00.068 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:30:00.057 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:40:00.049 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 03:50:00.054 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:00:00.061 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:10:00.100 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:20:00.055 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:30:00.064 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:40:00.273 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 04:50:00.050 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:00:00.064 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:10:00.050 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:20:00.046 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:30:00.080 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:40:00.060 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 05:50:00.050 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:00:00.081 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:10:00.069 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:20:00.052 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:30:00.047 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:40:00.079 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 06:50:00.050 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 07:00:00.078 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-06 07:10:00.065 [INFO ] [se.smarthome.model.script.LightsAuto] - Auto Light Check
2018-11-05 07:55:13.801 [vent.ItemStateChangedEvent] - AlleAusserHaus changed from OFF to ON
2018-11-05 08:02:13.281 [vent.ItemStateChangedEvent] - AlleAusserHaus changed from ON to OFF
2018-11-06 08:08:15.110 [vent.ItemStateChangedEvent] - AlleAusserHaus changed from OFF to ON
2018-11-06 13:13:38.941 [vent.ItemStateChangedEvent] - AlleAusserHaus changed from ON to OFF
Does someone have an idea, what is wrong in the code?
I would expect, that the lights only switch at the moment the variable
AlleAusserHaus
is equal to
ON
Thanks for your help in advance.
Dom
The way I read the logical expresseion in the if clause is “a and b or c”, but IMO it should read “a and (b or c)”.
Try breaking down the if statement:
    if (AlleAusserHaus.state == ON) {
        if (now.isAfter((Sunset_Time.state as DateTimeType).zonedDateTime.toInstant().toEpochMilli) || now.isBefore((Sunrise_Time.state as DateTimeType).zonedDateTime.toInstant().toEpochMilli)) {
@Rivi: Should be: if nobody is at home and is it between sunset and sunrise, then switch the lights periodically.
@vzorglub: l will try your code, and let you know the result.
Yes. But how is the computer supposed to know that if the logic statements are not grouped accordingly, to tell it that the first condition (not at home) must always be met, and then either one of the two others? At the moment, I suspect the rulen fires when not at home before midnight, and always after in the night. To put two if-clauses is sich a grouping, but I suspect parenthesis might have done it as well.
Yes, but nesting is easier to read in this case
