Hello folks, I have an Insteon dimmer. I have created an Item for it. However I would like to convert it to mqtt Dimmer. Where I want to broadcast it sates to my mqtt server and from other platform I be able to control it through mqtt. Any idea how I can go about this?
You would use the mqtt binding and create a generic thing with the dimmer type.
Have you got the dimmer working in openhab?
Well I could get around this few minutes ago by getting the node red to work. Now my question is different how can I adjust the brightness through item commands. For example when I pass on βONβ it will turn the light on. How can I pass on the brightness level?
I am unsure of th arcitecture you have setup in you system.
I have an item
Dimmer Kitchen_Light "Dimmer" [ "Lighting" ] {channel="mqtt:topic:myMQTTBroker:Kitchen:dimmer"}
In a sitemap to change the brigtness I have
Default item=Kitchen_Light icon="light"
This is setup by using my generic mqtt thing
//Broker Setup
Thing topic Kitchen "Bench Light" @ "Kitchen" {
Channels:
Type dimmer : dimmer [ stateTopic="Kitchen_Bench_Light/stat/DIMMER", transformationPattern="JSONPATH:$.Dimmer", commandTopic="Kitchen_Bench_Light/cmnd/Dimmer" ]
I use the vscode extention to edit config files here
Thanks for the examples, I got that. However, how can I use Item command to control a dimmer Item. Like how can I set its brightness to specific value through command?
LOL sorry I think I am not clear enough. You know the RESTapi page on your openhab instant lets say if you want to go to item list and command your dimmer to 50%. What kind of command do you put on the command field. The rules due it through local java variables.
Found it out, All I have to do is just pass on the value as integer with nothing else added. ie: post:items/{itemname}/ example 50
