Thanks Sajive, will try 'n let you know.
Regards,
Jan
Regards,
Jan
I canāt figure out where on this page I download the latest .jar file from the Jenkins site. I donāt have anything that remotely looks like a download link. Can anyone help?
Thanks for this! Worked perfectly (i also didnāt need the xstream jar).
To download the JAR file, click on the parent folder (openHAB2-Bundles). From there, click on Last Successful Artifacts, bindings, [the binding you are seeking], [binding].jar
cue Bruce with update script linkā¦
https://ci.openhab.org/job/openHAB2-Bundles is giving a 404 error and https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zwave/ does the same. Is there a new link?
This seems to work now:
https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.1-SNAPSHOT/
Hello. I am still on 2.5.11 (official what I get from apt repo) and have the known issue with Spirit Z-Wave Plus thermostat device. I would like to use the 2.5.10 version of the Z-Wave binding, but cannot find it anywhere. Does anybody have a link to the jar-file?
@chris - is there anywhere an official place, where older versions can be downloaded without having to worry about unknown and potentially malicious sources?
Updating to 3.x is no option for me, as I have spent so many hundreds of hours in my OpenHAB 2 system which I canāt (and wonāt) spend again.
If you are on 2.5.11, why do you want to use an older binding? Did it not have the device you need, but the older version does?
Iām not sure - this is really a question for the OH maintainers as Iām not involved in the distribution side.
In theory you can edit your existing JAR - itās just a ZIP file and you might be able to add the XML for the device you want, and it will likely work.
Hello @chris ,
I want to switch to 2.5.10 because my Spirit Thermostat does not work with later version (thereās a thread somewhere that says that there was a mistake introduced in the database in 2.5.11) and the recommendation is to go to 2.5.10.
As far as Iām aware there is no repository with these old versions.
