yep, it is installed via “apt-get install nodejs”
I found the sulution, the directorys are failed,
here is the working fontail.service:
[Unit]
Description=Frontail
[Service]
ExecStart=/usr/local/bin/frontail --ui-highlight -t dark /var/log/openhab2/openhab.log /var/log/openhab2/events.log
Restart=always
User=user
Group=user
Environment=PATH=/usr/local/bin/frontail
Environment=NODE_ENV=production
WorkingDirectory=/usr/local/bin/frontail
[Install]
WantedBy=multi-user.target
Alias=frontail.service
Thanks very much to the community to find the Solution!!!
Hi All
I can get this to start and display the logs with the config below, but there is no working directory or environment paths because I just could not get the darn thing to start with the entires above. What are they needed for? Using NGINX I cannot get to http://192.168.0.3/frontail
location /frontail/ {
proxy_pass http://localhost:9001;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
[Unit]
[Service]
ExecStart=/usr/local/bin/frontail --ui-highlight -t dark /var/log/openhab2/openhab.log /var/log/openhab2/events.log /var/log/openhab2/zwave.log
Restart=always
User=openhab
Group=openhab
[Install]
Don’t know if you solved this, but you need to use frontail with --url-path /frontail for it to work through nginx
