Having some issue with viewing the log viewer in web ui for a while now. Just done a full apt update so thought I’d finally get the issue resolved.
Running 2.4.0-1 on raspberry pi 3
The file the logviewer is trying to view is /var/log/openhab2/events.log
And the browser comes up with 192.168.1.113:9001 crashed.
Tried to follow a solved issue thread by reinstalling logviewer by openhabian-config which says it’s installed ok.
I then check systemctl status fronttail and it responds with no service found.
Any advice would be much appreciated I’ve probably missed something very simple!
Permissions look good. I installed OH via openhabian image and I have openhab:openhabian so maybe try using the openhabian-config tool and select Apply Improvements then Fix Permissions and System Tweaks to see if anything changes.
