@johntech you can do that with the sitemap, no rule needed. Here is one example that I use for doing what you describe.
ext item=Esp_Easy_Motion label="Garage Movement [%s]" labelcolor=[OFF="green", ON="red"] valuecolor=[OFF="green", ON="red"]
Just change the item name and label description can be whatever you like. You will also need to change the label color part OFF to CLOSED as well as the ON to OPEN like below
ext item=Esp_Easy_Motion label="Garage Movement [%s]" labelcolor=[CLOSED="green", OPEN="red"] valuecolor=[CLOSED="green", OPEN="red"]
Thanks for the links. and it works great. I need to do A LOT more reading on the OH system now that you helped me get it working. Thanks again!!
I think my next step is to monitor that switch or any switch I use, in OH, to change the enable switch on the BasicUI screen to disabled if communication fails as a visual indication of failure.
say I lose power to that board or the switch goes bad.
Glad is working and hope you have fun with OH. I guess the thread is solved, so please click the square box (near the heart icon) on the post that solved your issue.
