Since upgrade to M4 I see a lot of strange log entries like these:
2019-11-10 09:30:42.104 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/acIsOn' for the unknown item 'acIsOn'.
2019-11-10 09:31:06.557 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/turnOff' for the unknown item 'turnOff'.
2019-11-10 09:31:08.714 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/turnOff' for the unknown item 'turnOff'. 2019-11-10 09:31:09.234 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/turnOff' for the unknown item 'turnOff'.
2019-11-10 09:31:09.643 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/turnOff' for the unknown item 'turnOff'.
2019-11-10 09:31:13.167 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/acIsOn' for the unknown item 'acIsOn'.
2019-11-10 09:31:13.369 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/acIsOn' for the unknown item 'acIsOn'.
2019-11-10 09:31:23.369 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/sendCommand' for the unknown item 'sendCommand'.
2019-11-10 09:31:26.444 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'daikin.rules'
2019-11-10 09:35:53.199 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/msg' for the unknown item 'msg'.
2019-11-10 09:36:00.499 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/rule' for the unknown item 'rule'.
2019-11-10 09:36:00.806 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/rule' for the unknown item 'rule'.
2019-11-10 09:36:01.127 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/rule' for the unknown item 'rule'.
2019-11-10 09:36:01.477 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/rule' for the unknown item 'rule'.
2019-11-10 09:36:03.141 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/rule' for the unknown item 'rule'.
2019-11-10 09:36:22.957 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/state' for the unknown item 'state'.
2019-11-10 09:36:42.356 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/doorIsOpen' for the unknown item 'doorIsOpen'.
2019-11-10 09:36:43.257 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/tempBedroom' for the unknown item 'tempBedroom'.
2019-11-10 09:37:40.789 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/state' for the unknown item 'state'.
2019-11-10 09:38:03.469 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP GET request at 'items/is' for the unknown item 'is'.
These āaledgedā items are elements of the rules file, like this part for example:
// Get current temperature readings
var Number tempBedroom = (MB_AC_TempIn.state as QuantityType<Number>).doubleValue
var Number tempOutside = (MB_AC_TempOut.state as Number).doubleValue
// Set status variables to default state
var Number doorIsOpen = 0
var Number acIsOn = 0
// Set default state of the action variables
var Number turnOn = 0
var Number turnOff = 0
...etc...
else {
if (AC_Vacation.state == ON) {
logDebug(tag, "Vacation mode is on, turn off AC and exit Daikin rule")
MB_AC_Power.sendCommand(OFF)
...etc...
There are no errors when loading the rules or items file. Iāve done all the usual stuff like clear temp and cache.
Also, the word āisā as shown in the last log entry only appears on comment lines or in strings.
Currently I have no clue where to look to fix this. Any suggestion is welcomeā¦
