Continuing the discussion from Help with mail action gmail error Could not send e-mail (SOLVED):
Hi everyone.I tried everything you’ve suggested above. Still getting an error.
A mail has to be sent when a device connects to the network my RPi is connected to.
2018-12-12 16:30:00.852 [INFO ] [pse.smarthome.model.script.Test Mail] - Sending Mail
2018-12-12 16:30:02.249 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to '********
your code goes here
@gmail.com’.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp.gmail.com:465
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1421) ~[?:?]
at org.apache.commons.mail.Email.send(Email.java:1448) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:157) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:67) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:345) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: javax.mail.AuthenticationFailedException: 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbv8
534-5.7.14 LA5pNZBH3B3gNYYUd5xDLD4CzSMThsEiJZTBaTh_0vKjqx2386IKT5XKfBzbe5K21B3Fe9
534-5.7.14 cq7b25L97ZtMEYuCBlN9lrHvRKetpUs9nTc0U4FzxfUerCbFdhti-deun9JBHkb1oY5ZD3
534-5.7.14 IM00-1HbtktmxBOvIFQXwITSnm2ksZ1WHdArnTF8vcpRLatkmGIWZslfk_I3nU3dl5AoG8
534-5.7.14 wSXQnXS2DsPvRVKRBP9kmxRw7xglG0YV2_yCfXm7guKmaitJ62> Please log in via
534-5.7.14 your web browser and then try again.
534-5.7.14 Learn more at
534 5.7.14 https://support.google.com/mail/answer/78754 g190sm19785692pgc.28 - gsmtp
at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:809) ~[29:javax.mail:1.4.4]
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:752) ~[29:javax.mail:1.4.4]
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:669) ~[29:javax.mail:1.4.4]
at javax.mail.Service.connect(Service.java:317) ~[29:javax.mail:1.4.4]
at javax.mail.Service.connect(Service.java:176) ~[29:javax.mail:1.4.4]
at javax.mail.Service.connect(Service.java:125) ~[29:javax.mail:1.4.4]
at javax.mail.Transport.send0(Transport.java:194) ~[29:javax.mail:1.4.4]
at javax.mail.Transport.send(Transport.java:124) ~[29:javax.mail:1.4.4]
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1411) ~[?:?]
My rules file
rule “Send E-mail”
Item Status_Mobile_***** changed from OFF to ON
logInfo(“Test Mail”, “Sending Mail” )
sendMail("********@gmail.com", “Test”, “Mobile Connected”)
Any help is appreciated.
