Hello again guys,
so it seems like I am stuck now, can’t get the node back online even though I tried everything I did last time
The line that keeps showing up and I am mostly considered about is this:
[WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 30, child: 255 please insert it manually
2019-02-25 02:20:18.531 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.18:8080
2019-02-25 02:20:18.534 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.18:8443
2019-02-25 02:20:19.220 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-02-25 02:20:19.245 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTING - org.openhab.binding.mysensors
2019-02-25 02:20:19.252 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTED - org.openhab.binding.mysensors
2019-02-25 02:20:19.502 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=353, service.bundleid=216, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=212} - org.openhab.binding.mysensors
2019-02-25 02:20:19.856 [INFO ] [b.core.service.AbstractActiveService] - Expire Refresh Service has been started
2019-02-25 02:20:20.183 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
2019-02-25 02:20:20.191 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:1d520754' changed from UNINITIALIZED to INITIALIZING
2019-02-25 02:20:20.259 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
2019-02-25 02:20:20.264 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0, 1, 2, 3, 5, 6, 7, 8, 10]
2019-02-25 02:20:20.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
2019-02-25 02:20:20.300 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB30 [baudRate:115200]
2019-02-25 02:20:20.312 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=364, service.bundleid=216, service.scope=singleton} - org.openhab.binding.mysensors
2019-02-25 02:20:20.314 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
2019-02-25 02:20:20.316 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
2019-02-25 02:20:21.380 [DEBUG] [col.serial.MySensorsSerialConnection] - Serial port event listener started
2019-02-25 02:20:21.382 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
2019-02-25 02:20:21.409 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
2019-02-25 02:20:21.420 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;3;0;14;Gateway startup complete.
2019-02-25 02:20:21.431 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,1,2,3,5,6,7,8,10]
2019-02-25 02:20:21.434 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
2019-02-25 02:20:21.437 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:1d520754' changed from INITIALIZING to ONLINE
2019-02-25 02:20:21.440 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
java.text.ParseException: class java.lang.NumberFormatException : For input string: "Gateway startup complete."
at org.openhab.binding.mysensors.internal.protocol.message.MySensorsMessage.parse(MySensorsMessage.java:342) ~[216:org.openhab.binding.mysensors:2.4.0.201812040738]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:338) [216:org.openhab.binding.mysensors:2.4.0.201812040738]
2019-02-25 02:20:21.462 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;0;0;18;2.3.1
2019-02-25 02:20:21.496 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Presentation Message received
2019-02-25 02:20:22.296 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,1,2,3,5,6,7,8,10]
2019-02-25 02:20:22.301 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
2019-02-25 02:20:22.306 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 30;255;0;0;17;2.3.1
2019-02-25 02:20:22.309 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Presentation Message received
2019-02-25 02:20:22.316 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,1,2,3,5,6,7,8,10,30]
2019-02-25 02:20:22.321 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 30, child: 255 please insert it manually
2019-02-25 02:20:22.326 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 30;255;3;0;6;0
2019-02-25 02:20:22.330 [DEBUG] [rs.internal.gateway.MySensorsGateway] - I_CONFIG request received from M, answering: (is imperial?)false
2019-02-25 02:20:22.335 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 30;255;3;0;11;Temperature Sensor
2019-02-25 02:20:22.342 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 30;255;3;0;12;1.1
2019-02-25 02:20:22.342 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 30;255;3;0;6;M
bundle:list in karaf
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
20 │ Active │ 80 │ 5.3.1.201602281253 │ OSGi JAX-RS Connector
21 │ Active │ 80 │ 2.7.0.v20170129-0911 │ Gson: Google Json Library for Java
22 │ Active │ 80 │ 18.0.0 │ Guava: Google Core Libraries for Java
23 │ Active │ 80 │ 3.0.0.v201312141243 │ Google Guice (No AOP)
24 │ Active │ 80 │ 3.18.1.GA │ Javassist
26 │ Active │ 80 │ 3.5.5 │ JmDNS
28 │ Active │ 80 │ 1.0.0 │ Units of Measurement API
30 │ Active │ 80 │ 1.1.0.Final │ Bean Validation API
31 │ Active │ 80 │ 2.0.1 │ javax.ws.rs-api
32 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
35 │ Active │ 80 │ 3.2.1 │ Commons Collections
36 │ Active │ 80 │ 1.1 │ Commons Exec
37 │ Active │ 80 │ 2.2.0 │ Commons IO
38 │ Active │ 80 │ 2.6 │ Commons Lang
47 │ Active │ 80 │ 4.2.1 │ Apache Karaf :: OSGi Services :: Event
63 │ Active │ 80 │ 4.6.0 │ Apache XBean OSGI Bundle Utilities
64 │ Active │ 80 │ 4.6.0 │ Apache XBean :: Classpath Resource Finder
65 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Common
66 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Ecore
67 │ Active │ 80 │ 2.11.0.v20160420-0247 │ EMF Change Model
68 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF XML/XMI Persistence
69 │ Active │ 80 │ 3.8.0.v20160509-1230 │ Common Eclipse Runtime
70 │ Active │ 80 │ 3.6.100.v20160223-2218 │ Extension Registry Support
80 │ Active │ 80 │ 9.4.11.v20180605 │ Jetty :: Proxy
94 │ Active │ 80 │ 0.4.1.v20180515-1321 │ org.eclipse.lsp4j
95 │ Active │ 80 │ 0.4.1.v20180515-1321 │ org.eclipse.lsp4j.jsonrpc
96 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome OAuth2Client
97 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Core
98 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration Discovery
99 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration mDNS Discovery
100 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Dispatcher
101 │ Active │ 75 │ 0.10.0.oh240 │ Eclipse SmartHome Config XML
102 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core
103 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Audio
104 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Binding XML
105 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core ID
106 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Persistence
107 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Scheduler Service
108 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Semantics
109 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Thing
110 │ Active │ 75 │ 0.10.0.oh240 │ Eclipse SmartHome Core Thing XML
111 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Transformation Service
112 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Voice
113 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Console
114 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Console for OSGi runtime Karaf
115 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome HTTP Interface Bundle
116 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome JavaSound I/O, Fragments: 183
117 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Monitor
118 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Net I/O Bundle
119 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST Interface Bundle
120 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core REST API
121 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST mDNS Announcer
122 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST Interface JAX-RS optimization Bundle
123 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap REST API
124 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome SSE REST API
125 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Voice REST API
126 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Bonjour/MDS Service Discovery Bundle
127 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Web Audio Support
128 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Model Core
129 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model
130 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model IDE
131 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model Runtime
132 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Language Server
133 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Model
134 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Model IDE
135 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Runtime
136 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Model
137 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Model IDE
138 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Runtime
139 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script
140 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script Model IDE
141 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script Runtime
142 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Model
143 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Model IDE
144 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Runtime
145 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model
146 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model IDE
147 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model Runtime
148 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Json Storage Service
149 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome UI
150 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome UI Icons
151 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Classic IconSet
152 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xtend Runtime Library
153 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xtend Macro Interfaces
154 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext
155 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xtext Common Types
156 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext IDE Core
157 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext Utility
158 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xbase Model
159 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xbase Generic IDE Services
160 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xbase Runtime Library
175 │ Active │ 80 │ 1.9.6 │ MIME streaming extension
177 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm
178 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm.commons
179 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm.tree
180 │ Active │ 90 │ 2.4.0 │ openHAB Core
181 │ Active │ 80 │ 2.4.0 │ openHAB Karaf Integration
183 │ Resolved │ 80 │ 2.4.0 │ openHAB Sound Support, Hosts: 116
184 │ Active │ 80 │ 2.4.0 │ openHAB Dashboard UI
189 │ Active │ 80 │ 1.0.2 │ Units of Measurement Common Library
190 │ Active │ 80 │ 1.0.8 │ Units of Measurement Implementation for Java SE
196 │ Active │ 80 │ 2.4.0 │ HomeBuilder User Interface
199 │ Active │ 80 │ 3.14.0 │ nrjavaserial
200 │ Active │ 80 │ 3.15.0.OH2 │ nrjavaserial
201 │ Active │ 80 │ 3.3.0 │ Commons Net
202 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration USB-Serial Discovery
203 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration USB-Serial Discovery Linux sysf Scanning
204 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Serial
205 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport
206 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport for RXTX
207 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport extension for RXTX RFC2217
208 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Basic UI, Fragments: 210
209 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Paper UI, Fragments: 212
210 │ Resolved │ 75 │ 2.4.0 │ openHAB Basic UI Fragment, Hosts: 208
211 │ Active │ 80 │ 2.4.0 │ HABPanel User Interface
212 │ Resolved │ 75 │ 2.4.0 │ openHAB Paper UI Theme Fragment, Hosts: 209
213 │ Active │ 80 │ 1.2.0 │ Paho MQTT Client
214 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome MQTT Transport Bundle
216 │ Active │ 80 │ 2.4.0.201812040738 │ MySensors Binding
217 │ Active │ 80 │ 1.6.0 │ Commons Codec
218 │ Active │ 80 │ 4.2.3 │ Apache HttpClient OSGi bundle
219 │ Active │ 80 │ 4.2.3 │ Apache HttpCore OSGi bundle
220 │ Active │ 80 │ 3.1.0.7 │ Apache ServiceMix :: Bundles :: commons-httpclient
221 │ Active │ 80 │ 1.13.0 │ openHAB Mail Action
222 │ Active │ 80 │ 2.4.0 │ openHAB 1.x Compatibility Layer
223 │ Active │ 80 │ 1.13.0 │ openHAB Expire Binding
224 │ Active │ 80 │ 1.13.0 │ openHAB InfluxDB Persistence bundle
