The binding is now part of openhab 2.4 and can be installed directly from within PaperUI.
So i have begun to develop a binding for the konnected alarm panel. konnected.io
I am still in the very early stages here but hope to eventually have a full fledged binding. So far i can detect the konnected module via ssdp and have it added as a thing. I need some guidance on where to head next.
So the konnected device can be programed via a rest put command to send out updates to an ip address (via put with a json payload) when the status of a sensor changes. Payload is of the form (pin:1 state:1) What I think i need to do is program the binding to have an http servelet (via jetty or something else) that can serve as a sink for these commands to be sent where i can then have the binding pass the commands onto a channel that can be linked to an item.
Are there any examples that i can look to for this type of server? Or should i be taking another route with this design? Any thoughts or help would be appreciated.
I’m disappointed with Konnected it wasn’t just an MQTT based device, it seemed tied to Smarthings which is annoying. Does the Home Assistant binding contain any useful code? As I believe out of the box it was supposed to be supported.
It’s not tied to smart exclusively at all. It has a restful API that can be used to communicate with the device and it advertises itself via Ssdp. So I would say it’s actually pretty open for any automation controller to talk with.
I was able to look at the Neatmo binding which I think I can adapt for use in the konnected binding. The neat mobile binding creates a web socket where the neatmo API can send restful commands to.
with its webhook servelet. I do not have any erros in my code when it compiles, however, i am my thing is getting an UNINITIALIZED - HANDLER_INITIALIZING_ERROR
and this code is in the log:
2018-06-19 15:47:18.285 [DEBUG] [.b.k.internal.KonnectedHandler:68 ] - Setting up Netatmo Welcome WebHook
2018-06-19 15:47:18.288 [ERROR] [.i.c.AbstractInvocationHandler:101 ] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.konnected.internal.KonnectedHandler@3ca9f17d': nulljava.lang.NullPointerException: null
at org.openhab.binding.konnected.internal.servelet.KonnectedHTTPServelet.activate(KonnectedHTTPServelet.java:58)
at org.openhab.binding.konnected.internal.KonnectedHandler.initialize(KonnectedHandler.java:69)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153)
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
2018-06-19 15:47:18.293 [ERROR] [.c.thing.internal.ThingManager:706 ] - Exception occurred while initializing handler of thing 'konnected:module:16631321': nulljava.lang.NullPointerException: null
Ok so i got the service working. It was an OSGI error and i did not have the proper reference to the sethttpservices and unsethttpservices methods set in the handlerfactory.
Now the servelet starts and is able to receive messages at the appropriate path.
I need to have the binding send put and get requests. I know there are several bindings that already do this. I know there are a million ways this can be done. What is the best way to do this in a binding? Is there a preferred method or package set i should use? Does eclipse have a framework that can be utilised for this?
Ok i have the requests issue worked out using the Httputil command from eclipse. New issue.
So the put request is sent to the connected module to setup the pins. When the put request is sent the device resets. I have the binding setup to create the configuration that is being sent via channel linking. So when a channel is linked or unlinked it adds/removes information to the request.
So the problem is that I only want to actually call the put method once, or at least only every so often so that all changes are grouped together and send.
public void channelLinked(ChannelUID channel) {
// adds linked channels to list based on last value of Channel ID
// which is set to a number
logger.debug("Channel {} has been linked", channel.getId());
sensors.add("{\"pin\":" + channel.getId().substring((channel.getId().length() - 1)) + "}");
logger.debug(sensors.toString());
updateKonnectedModule();
So conceptually i think i need to have updateKonnectedmodule() only run if its not called again within some timeframe?
Ok solved that problem and now i have a working alpha version of the binding that runs in the IDE but i can’t get it to compile with maven. Any ideas?
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: org.openhab.binding.konnected 2.4.0.qualifie
r
[ERROR] Missing requirement: org.eclipse.smarthome.config.core 0.10.0.20180614
1343 requires 'package org.eclipse.smarthome.core.common 0.0.0' but it could not
be found
[ERROR] Cannot satisfy dependency: org.openhab.binding.konnected 2.4.0.qualifi
er depends on: package org.eclipse.smarthome.config.core 0.0.0
[ERROR]
[ERROR] See http://wiki.eclipse.org/Tycho/Dependency_Resolution_Troubleshooting
for help.
[ERROR] Cannot resolve dependencies of MavenProject: org.openhab.binding:org.ope
nhab.binding.konnected:2.4.0-SNAPSHOT @ C:\OPENHABDEV\openhab2-master2\git\openh
ab2-addons\addons\binding\org.openhab.binding.konnected\pom.xml: See log for det
ails -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MavenExecution
Exception
Ok so still can’t get it to compile but moving forward with development. Hopefully someone will eventually see this and be able to help me. However. I have a new problem… I need to add configuration parameters to some of my channels. However, whenever i add the value i get null pointer exceptions in the log and the binding doesn’t work:
2018-06-26 15:25:59.165 [DEBUG] [e.s.a.core.internal.RuleEngine:256 ] - ModuleHandlerFactory added.
2018-06-26 15:25:59.169 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
at org.openhab.binding.konnected.internal.KonnectedHandler.channelLinked(KonnectedHandler.java:124)
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.lang.Thread.run(Thread.java:748)
2018-06-26 15:25:59.170 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
2018-06-26 15:25:59.174 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
2018-06-26 15:25:59.175 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
2018-06-26 15:25:59.177 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
2018-06-26 15:25:59.178 [ERROR] [.c.thing.link.ThingLinkManager:302 ] - Exception occurred while informing handler: nulljava.lang.NullPointerException: null
I posted a link to my code above in github but
in my config.xml
<config-description uri="channel-type:konnected:zone">
<parameter name="config_isActuator" type="boolean">
<label>IsActuator</label>
<description>Is the thing connected an actuator</description>
<default>false</default>
</parameter>
</config-description>
and my channels.xml files
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="konnected"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 org.eclipse.smarthome.thing-description.xsd">
<!-- Zone Channel Type -->
<channel-type id="zone">
<item-type>String</item-type>
<label>Pin</label>
<description>The Zone Channel for adding Sensors</description>
<config-description-ref uri="channel-type:konnected:zone" />
</channel-type>
</thing:thing-descriptions>
Just as an update i have the binding working now and a pull request has been created. There is a working version of the binding at the top of the pull request.
Thanks for your work on this Zachary Christiansen!
I’m in the early stages of setting up my smart home. I’m planning on using Konnected. Originally I was going to use Home Assistant. At that point, Konnected made sense. Eventually, I decided that I liked the OpenHAB interface more. I was worried that I would have to write my own binding for Konnected. Then, I saw the work you have done. Your binding will be a huge help.
Like I said, I’m in the early stages. I bought all the security sensors and wires. I still have to run wires and install the sensors. I still need to buy my Konnected. I was thinking I would overkill it and get the 24 zone kit.
I am a web developer. I stared your git repo.
Does your binding support more than 6 zones? I ask because I only saw 6 zones in the thing-types.xml file.
I was also thinking that as I set it up I would document my steps and submit a pull request to update the Readme with more information. I figure that’s the least I could do to be helpful.
So each konnected module itself only supports 6 zones. However the binding can support as many modules as you want. ( I currently use 5) so if you need more than 6 zones you just add more modules and you will have a seperate thing for each module.
So the pull request is currently being reviewed. However i have been running the code that is in the pull request on my server for awhile now with no major issues. I am happy to walk you though setup of the manual add-on. As to when it will be merged in that will depend on when the review is completed and the time it takes for me to make the necessary changes to the review code.
Appreciate the fast response, I was out for a couple days so I was not able to reply then. I am still in the stages of research on what or how I want to convert our wired system to smartthings. I read in a previous comment that they thought this was tied to smartthings, I just want to clarify something as a noobie, what is the path of the communication with konnected? If my internet cuts out, will this still work locally with openhab? Also how would you compare the Konnected with the EyezOn EnvisaLink?
Correct. The konnexted modules communicate directly with openhab over the local network and are not internet dependent. So if your internet goes out the modules with will send the signals to openHAB.
As to the eyes on product I have not seen that product so can’t coment. But from my view it looks like some notable differences are the konnected decices are Wi-Fi, have support for more zones per board (6).
I’m sold on the idea. I just ordered a 12 zone kit the other day. I think I can manage myself but If I have any other questions to ask you or need help on the install where is the best place to reach you?
