Ok thanks, i am rebuilding that right now and about to upload a new one. - and its updated now
its updated now
Initial impressions, it might work but when the thing is added it still says âInternal Server ERROR: 500â
It might work anyways because it says the thing is ONLINE this time instead of UNKNOWN as before.
Iâll play around for a bit and see if there are any problems with it.
EDIT:
The buzzer is working now!
if you still have trace logging on would you mind sharing you logs with me? I have been seeing the internal log error some times as well and canât pin down what it is.
Awesome that you have the buzzer working! let me know if you run into any other issues.
So I was doing some further testing with actuators and sensors, they both seem to work just fine, but sometimes the Konnected modules lie to you and say theyâre offline when theyâre not, and even still accepting commands oddly. Functionality seems to be just fine so far, besides needing to manually sending config update every time you make a change to the channels and things. Iâm hooking it up into my security panel tomorrow and actually doing the coding.
All in all great work!
I added the state monitoring updates late in development so perhaps i need to flesh it out a bit. But the basic idea is that it sets it to offline whenever there is a communication error on the server end but then will set it back online if it receives a message the module. So my suspicion here is that there was an error for some reason (the binding threw an exception, etc.) but then the module later sent a message so the thing was set back online. Or i may have not coded it properly and need to tweak it. But i would need to look through your logs to confirm. If you have your logs that would be great.
As to the updating of the module. So the binding sends a command to the module on three occasions when openhab is first started, when there is a configuration change, or if the user manually triggers it via the configuration switch. This is currently by design. I choose not to send on channel adds or deletes because of the modules response to receipt of updated settings. So when the module receives a settings update it reboots which takes about 20-30 seconds before the device comes back online. Thus if the user is adding or deleting several channels quickly (such as during the initial setup) there could be several commands that would be sent and potentially not received by the device (if it were in the middle of rebooting) if i were to trigger an update on channel adds or deletes. At this point i have made a design decision to not trigger on channel adds as for the most part this configuration does not happen that often, however, i am open to suggestions on how to handle this more elegantly?
Perhaps this needs to be communicated to the user better? Such as an update to the thing status to indicate that an update in settings should be sent on channel adds and deletes? This status could then be cleared when the module was updated?
Thanks for all your testing!
Sorry for the late response, I am still confused as to why I sometimes do and sometimes I donât get an email to updates to threads Iâm subbed to.
https://puu.sh/C0w0P/3781c6ae2b.log
Here is the latest log file after running the modules for a few days. Everything is running as expected, but there are some interesting exceptions being thrown. Again I have not personally noticed any functionality issues.
As to the updating the channel configurations, I can understand the issue there. In my experience the module takes about 10 seconds to receive and reboot with the new configuration. I think changing the status to pending and note to send update config manually is a great idea. Its not a big deal after you know about its quirks but that could throw off a new user.
Im looking at using this binding, can someone please explain how to install the latest version. Its either this, Or i create my own using MQTT commands.
So go to the pull request linked in the above post and download the .jar from the top post of the pull request on github. Then place the.jar (you will need to unzip) in your addons folder. Then you will need to run the command feature:install openhab-transport-upnp from the karaf console. This will install the binding dependency. Then restart openhab.
Thanks for the reply, Done that. And the thing is found easily enough, But its asking for an AUTH TOKEN. This isnât automatically produced.
Also. do you have an Items file example i can start with?
Ok. So after some testing.
I have created the Auth token myself, seems its a number i can select, and then that is what i use in the items file to link to the channel
I have added channels myself Zone_1 to Zone_6
And I have figured which pins are connected to which zones on the unit
I have also figured that If i add Aux_1 to Aux_6 it turns that zone/pin into an output
One question i have though, does openhab control the zones and then sirens, or does the Konnected firmware trigger a siren when the zone is open/closed.
I have found no way of changing the konnected firmwares settings, is there an option or a way for this to happen.
More documentation on this would be brilliant.
One other thing, when the device goes offline, there is no notification of it.
It just stays as online,
The openHAB konnected binding is sending the commands to the alarm panel modules. So if you setup a channel as an actuator type and then send a command of either OFF or ON the binding will then transmit that command to the alarm panel of the thing. The firmware on the alarm panel itself will then receive that command and transmit the command to the physical device itself.
This is correct. However, I am still developing the binding and I am about to release a revised version of the binding with the binding itself will handle the auth token and this will not need to be configured by the user at all. But with the current version as of 11/14 you are correct that it will accept any string.
Which settings are you referring to? The binding can has the ability to send settings for blink and to disable device discovery. Both of these can be found under the configuration page under the show more tab. However, be careful with disabling the device discovery that you have assigned a static IP address and that the thing was added to openHAB with the static IP address. Otherwise the binding will not be able to communicate with the alarm panel and you will have to manually reset the alarm panel via its status page. (which can be found at http://deviceip/port, this is address is listed on the properties of the thing, the port is randomly set by each alarm panel and is not configurable.
here is a link to the current readme, its a work in progress.
Still developing the binding and working through the notification system. Definitely still some kinks to work out. Right now the binding will put the thing offline when there are any communication errors, but will put the device back online when it receives a command from the module. I probably need to have it recheck on communication failures before setting it offline to confirm that the particular failure wasnât just a one off failure.
Thank you for testing and please report any and all bugs or issues you come across here so i can work on them.
I want to thank you for your work on this.
I initially thought the Alarm system worked on the NODEMCU completely and OH just handled some commands and also notifications. But I was wrong, I now understand the Konnected device just sends contact status to OH and also receives actuator status from OH. so if OH is off, the alarm system wont work. This means ill have to input some sort of battery backup for my router, OH sytem and the konnected devices.
I have worked out the commands and channels last night, but I would suggest that the channels automatically come through in a future revision of the binding.
Zone_1, Zone_2, Zone_3, Zone_4, Zone_5, Zone_6 and Zone_7 are the channels i worked out. Also Aux_1,Aux_2,Aux_3,Aux_4,Aux_5,Aux_6.
Zone_7 being the siren output.
Also, if you have an Aux_n (where n being a zone number) set, it turns that zone into an OUTPUT on the Konnected device, and not an INPUT as a zone.
Is there a channel for a beeper? Lets say for instance a door is opened while the alarm is set in OH, and you want a beeper to go off for 10 seconds before the siren does. Is there a channel for this, or do you just set it using an Aux channel?
Do you have an Items file example i can look at, Maybe a sitemap example also. I currently have a sitemap and items file setup for an alarm system that is pretty crude, it has a keypad, with a pre configured code that needs to be entered. Then you can arm, disarm, or stay the alarm, and this then presses buttons on a remote that i have wired up. Its crude but it works.
Now that i know the pinouts, im in the process of making my own addon board similar to Konnectedâs.
Also, I would add, in the binding, maybe you can change whether a contact is NO or NC, as some contacts do not have multiple configurations and are set already as either NO or NC. This way you wont have to alter OH code to account for a reversed contact.
Edit: I have just read the readme, some of my questions above are actually answered
I think this is in the readme, but you set it up as an actuator channel. As per the konnected alarm panel specs zones 1-5 or the out terminal can function as an actuators. So you can pick any of those. Then set the config parameters for times,pause and momentary as appropriate for your needs. For the rest of this part you would need to have two things setup. A beeper and then the siren. Then you would want a rule that first fires the beeper for ten seconds ⊠and then if something doesnât happen in ten seconds it activates the siren channel. There are several ways that this could probably be done in rules i havenât personally done it but i would search the design patters or forums here first for that specifically for some ideas. (sorry not to pass the buck on this one).
So the two channels that are added are a design choice. There are numerous configurations for each thing (I have several in my house and they each have multiple types on them) However the reason i have these two as defaults is because physically speaking on the alarm board zone 6 is always a sensor (it could be a temp sensor so then you would delete this channel) but the out is always the out. Thus these two serve as an example of the base functionality (actuator/sensor) while not requiring alot of channels to be deleted for every thing that is added. For my things i only have channels for things i actually have connected to the panel. The thing is extensible and the user can add whatever channels there particular situation requires.
So currently the binding itself is agnostic to the state of the device. If the alarm panel sends a 0 it reports it as closed and if it sends a 1 it reports it as open. Or on off for the actuator type. I didnât think that a config parameter here was necessary as the user can easily change what these mean in the sitemap or other UI interfaces. For example the open/closed states can be mapped to whatever the user desires to present. But i am open to rethinking this as i know there are some UI elements that derive from the physical state and not its presentation.
/* Konnected Sensors*/
Contact Konnected_Zone_1 "Middle M" (Motion_Sensors){channel="konnected:module:1586287:Zone_3"}
Contact Konnected_Zone_4 "Back M" (Motion_Sensors) {channel="konnected:module:4543348:Zone_3"}
Contact Konnected_Front_Zone_2 "Front Motion" (Motion_Sensors) {channel="konnected:module:1586517:Zone_2"}
Switch Konnected_Out "Siren" {channel="konnected:module:16631321:Zone_7"}
Contact Konnected2_Zone_1 "Door Bell" {channel="konnected:module:1673491:Zone_1"}
Contact Konnected2_Zone_2 "Den Right Window" {channel="konnected:module:1673491:Zone_2"}
Contact Konnected2_Zone_3 "Den Left Window" {channel="konnected:module:1673491:Zone_3"}
Contact Front_Door_Sensor "Front Door" {channel="konnected:module:1673491:Zone_6"}
Contact Back_Door_Sensor "Back Door" {channel="konnected:module:1673491:Zone_5"}
Contact Konnected2_Zone_4 "Smoke Alarm" {channel="konnected:module:1673491:Zone_4"}
Switch Konnected2_Out "Motion" {channel="konnected:module:1673491:Zone_7", expire="5s, command=OFF"}
Contact Konnected_Den_Zone_2 "Den" (Motion_Sensors) {channel="konnected:module:3830205:Zone_2"}
/*Konnected AC Control */
Switch Konnected_AC_Out "Relay Power" {channel="konnected:module:14108879:Zone_7"}
Switch Konnected_AC_Zone_1 "Zone 1" {channel="konnected:module:14108879:Zone_1"}
Switch Konnected_AC_Zone_2 "AC Control" {channel="konnected:module:14108879:Zone_2"}
Switch Konnected_AC_Zone_3 "Zone 2" {channel="konnected:module:14108879:Zone_3"}
Switch Konnected_AC_Zone_4 "Zone 4" {channel="konnected:module:14108879:Zone_4"}
Switch Konnected_AC_Zone_5 "Zone 5" {channel="konnected:module:14108879:Zone_5"}
Number:Temperature Konnected_Attic1 "Attic Temperature [%.1f °F]" <temperature>(Temp) {channel="konnected:module:14108879:AtticTemp6"}
Number:Temperature Front_Den_Temperature "Living Room [%.1f °F]" <temperature>(Temp) {channel="konnected:module:1586517:Zone_1"}
Number:Temperature Kitchen_Temperature "Kitchen [%.1f °F]" <temperature>(Temp) {channel="konnected:module:1586287:Zone_1"}
Number:Temperature Stairway_Temperature "Stairway [%.1f °F]" <temperature>(Temp) {channel="konnected:module:4543348:Zone_1"}
Number:Temperature Den_Temperature "Den [%.1f °F]" <temperature>(Temp) {channel="konnected:module:3830205:Zone_1"}
Number:Temperature Server_Closet_Temperature "Server Closet [%.1f °F]" <temperature>(Temp) {channel="konnected:module:3830205:Zone_3"}
Number:Temperature Konnected_Outside_Temperature "Outside Temperature [%.1f °F]" <temperature>(Temp) {channel="konnected:module:3830205:Zone_4"}
Switch item=Front_Door_Sensor label="Front Door" icon="frontdoor" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Back_Door_Sensor label="Back Door" icon="door" mappings=[OPEN="Open", CLOSED="Closed" ]
Switch item=Motion_Shed_Door icon="door" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected_Zone_4 icon="motion" mappings=[OPEN="Open",CLOSED="Closed"]
Switch item=Konnected_Front_Zone_2 icon="motion" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected_Zone_1 icon="motion" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected_Den_Zone_2 icon="motion" mappings=[OPEN="Open",CLOSED="Closed"]
Switch item=Konnected2_Zone_2 icon="window" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected2_Zone_3 icon="window" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected2_Zone_1 icon="door" mappings=[OPEN="Open", CLOSED="Closed"]
Switch item=Konnected2_Zone_4 icon="fire" mappings=[OPEN="Alarm", CLOSED="Off"]
Switch item=Konnected_Out icon="siren" mappings=[ON="Open", OFF="Closed"]
Switch item=Konnected2_Out icon="Alarm" mappings=[ON="Open", OFF="Closed"]
Text item=Front_Den_Temperature
Text item=Kitchen_Temperature
Text item=Stairway_Temperature
Text item=Den_Temperature
Text item=Server_Closet_Temperature
Text item=Konnected_Outside_Temperature
rules file
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function3<GenericItem, GenericItem, GenericItem, Object> motionSwitch= [relayItem, AlarmItem, TriggerItem |
if (AlarmItem.state==ON){
logDebug("Alarmrule.rules","Opening the alarm trigger as system is Armed")
relayItem.sendCommand(ON)
sendNotification("volfan6415@gmail.com", "Activating the alarm from sensor: " + transform("MAP", "sensorName.map", TriggerItem.name))
else{
logDebug("Alarmrule.rules","System was not armed so not activating the switch")
rule "Back Door Open"
Item Back_Door_Sensor changed from CLOSED to OPEN
Back_Door_Control.sendCommand(ON)
motionSwitch.apply(Konnected2_Out,Armed,Back_Door_Control)
rule "Front Door Open"
Item Front_Door_Sensor changed from CLOSED to OPEN
motionSwitch.apply(Konnected2_Out,Armed,Front_Door_Sensor)
Front_Door_Control.sendCommand(ON)
Echo_Den_TTS.sendCommand("Front door opened.")
rule "Shed Door Open"
Item Motion_Shed_Door changed from CLOSED to OPEN or
Item Motion_Shed_Door changed from NULL to OPEN
Light17.sendCommand(ON)
motionSwitch.apply(Konnected2_Out,Armed,Motion_Shed_Door)
rule "Motion Sensors"
//back motion
Item Konnected_Zone_4 changed from CLOSED to OPEN or
//front motion
Item Konnected_Front_Zone_2 changed from CLOSED to OPEN or
//middle motion
Item Konnected_Zone_1 changed from CLOSED to OPEN or
//den motion
Item Konnected_Den_Zone_2 changed from CLOSED to OPEN
//only send the motion switch to trip alarm when we are away
Motion_Sensors.members.filter[motion | motion.state == OPEN].forEach[motion|
if (System_State.state == OFF){motionSwitch.apply(Konnected2_Out,Armed,motion)}
else{Armed_Automation.sendCommand(OFF)}
Motion_Ten.sendCommand(ON)
rule "back motion"
Back_Motion_Control.sendCommand(ON)
rule "front motion"
Front_Motion_Control.sendCommand(ON)
rule "middle motion"
Kitchen_Motion_Control.sendCommand(ON)
rule "den motion"
Den_Motion_Control.sendCommand(ON)
rule "Back Window Right or left"
Item Konnected2_Zone_2 changed from CLOSED to OPEN
motionSwitch.apply(Konnected2_Out,Armed, Konnected2_Zone_2)
Item Konnected2_Zone_3 changed from CLOSED to OPEN
motionSwitch.apply(Konnected2_Out,Armed, Konnected2_Zone_3)
rule "Alarm Set"
Item Armed changed from OFF to ON
Echo_Den_TTS.sendCommand("Be careful when leaving. The Alarm is now set.")
rule "Armed Automation - Off"
Item Armed_Automation received command OFF
Armed.sendCommand(OFF)
rule "Armed Automation - ON"
Item Armed_Automation received command ON
if (System_State.state == ON){
logDebug("Alarmrule.rules","People are home so we are not auto re arming the system")
//unless it is between 1-7 in the morning then we are sleeping and so we will rearm the system
if (vTimeOfDay.state == "BED"){
Armed.sendCommand(ON)
else{
logDebug("Alarmrule.rules","no one is home so rearming the system")
rule "smoke alarm"
Item Konnected2_Zone_4 received command OPEN
Echo_Den_TTS.sendCommand("Smoke Alarm Active.")
Echo_Bedroom_TTS.sendCommand("Smoke Alarm Active.")
Echo_Kitchen_TTS.sendCommand("Smoke Alarm Active.")
sendNotification("volfan6415@gmail.com", "Smoke Alarm Active.")
I should also add that that the basic function of my arming and disarming works off of the design pattern from the presence detection. (Design Pattern: Sensor Aggregation) But the idea is that i have all of the senors that i want to track if people are home or not (phones, doors opening and closing, my media center playing, motion sensors, etc.) then when all of those leave the system arms itself.
The system also arms itself via our good night routine that is fired off via our amazon echos.
rule "Everyone is Gone"
Item System_State changed from ON to OFF
logDebug("Presense.rules","Everyone is gone so we are locking the front doors and tunring the lights off and arming the system")
Lights.sendCommand(OFF)
Front_Door_Lock.sendCommand(ON)
Shed_Door_Lock.sendCommand(ON)
Switch System_State "Home/Away" (Persist)
Switch Armed_Automation (Persist) {expire="1h, command=ON"}
Switch Armed "Sensor Status: [MAP(Armed.map):%s]" (Persist)
The armed automation group functions to allow my motion sensors to auto disarm and arm the sensor when we are at home and sleeping as detected by our phones. Otherwise if our phones arenât present it will activate the alarm on the motion sensor movement. But if the phones are home it does not activate the alarm.
Also i am more than happy to discuss this in more detail with you, but donât want to hijack this thread which i would like to keep focused on the konnected binding itself. I posted the above as it is still related and others using will find it useful. But if we want to discuss it further lets start a separate thread.
Thanks for that
I understand most of it now.
where you said
Blockquote
do you mean an you would need two âitemsâ setup in the items file, not âthingâ.
I already have alarm rules setup, and working. so this would be easy to integrate.
If you want the siren to beep and then blare with different tone differences you will need difference channels âŠ
But question in the physical device sense are you trying to make two difference devices beep or one device behave differently?
what i mean is in the samsung smartthings app, there are more âthingâ types than what you have in your binding.
They have beepers.
I assume that for me to connect a beeper, I just put it in a zone, change that zone to an actuator and adjust the pulses.
Then I have an item linked to that thing, and a rule that triggers that item.
