[WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
If I put “Save” the widget is placed but without the assigned item.
I have been trying to do something similar with a humidity sensor and the same thing happens, I add the item but at the time of adding it, there are no changes.
An issue has already been filed for this. The solution is you have to fill in the title and all the other properties that use props to use the actual Item and title.
I got it, editing in the “code” tab, there was no way to edit from the “design” tab -> “config item”. Just out of curiosity, why is this happening?
Thank you.
No because it’s not a problem with the code. It’s a problem with using a custom widget on the Overview tab. There is nothing you can change in the code to make it work.
I believe this problem has been fixed but you should search Github for related issues to be sure.
Hi All, I think im trying to do something similar. My widget puts the itemname by default, which is too long for the MainUI to look clean. If I go and edit the code of the page and enter this:
