I’m trying to manipulate a Switch-item to be an one-push-button. I already succeeded by using “mapping” in sitemap-data. But that’s not the best way working for me.
So my question: Is there any way to manipulate a Switch button to be a one-push-button?
An alternative solution would be, that the switch toggles automatically back to OFF-state without using rules.
Use Expire binding (you may need to install it) for auto-off Item. You can choose to command or update it, which choice might be about what you are doing with it e.g. other bindings.
Switch PushButton "Press me" { expire="1s,command=OFF" }
You’ve already found Sitemap mappings, which allow you to make it look like a button.
