@ssalonen, I have added the parameter timeBetweenTransactionsMillis=0 and the reponsetime for writing a change from the sitemap is now as low as I was used to with V1, more or less immediate.
My bridge now looks like this:
Bridge modbus:tcp:SH2WEB [ host=“192.168.1.198”, port=502, id=1, timeBetweenTransactionsMillis=0, reconnectAfterMillis=60000]
I have 133 things using this bridge.
CPU-info as follows (in “idle”-mode). I don’t know if it is good or bad?
top - 15:51:28 up 73 days, 20:45, 1 user, load average: 1.40, 1.43, 1.45
Good that the original issue in this thread was solved. Consider marking your own reply as the answer.
Cpu load will be pretty high when each poll of data updates the channels of 100+ things . For this reason, there is the experimental version above, updating the channels less regularly.
I will do this, if it is solved…today no rules are executing and I see this as the last loginfo:
2019-01-06 14:31:03.198 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.InternalError: BMH.reinvoke=Lambda(a0:L/SpeciesData<LLLI>,a1:L)=>{
t2:L=MethodHandleImpl.array(a1:L);
t3:I=BoundMethodHandle$Species_L3I.argI3(a0:L);
t4:L=BoundMethodHandle$Species_L3I.argL2(a0:L);
t5:L=BoundMethodHandle$Species_L3I.argL1(a0:L);
t6:L=BoundMethodHandle$Species_L3I.argL0(a0:L);
t7:L=MethodHandle.invokeBasic(t6:L,t5:L,t4:L,t3:I,t2:L);t7:L}
at java.lang.invoke.MethodHandleStatics.newInternalError(MethodHandleStatics.java:127) ~[?:?]
at java.lang.invoke.LambdaForm.compileToBytecode(LambdaForm.java:660) ~[?:?]
at java.lang.invoke.LambdaForm.prepare(LambdaForm.java:635) ~[?:?]
at java.lang.invoke.MethodHandle.<init>(MethodHandle.java:461) ~[?:?]
at java.lang.invoke.BoundMethodHandle.<init>(BoundMethodHandle.java:58) ~[?:?]
at java.lang.invoke.BoundMethodHandle$Species_L3I.<init>(Species_L3I) ~[?:?]
at java.lang.invoke.BoundMethodHandle$Species_L3I.copyWith(Species_L3I) ~[?:?]
at java.lang.invoke.MethodHandle.asCollector(MethodHandle.java:1002) ~[?:?]
at jdk.internal.dynalink.DynamicLinker.createRelinkAndInvokeMethod(DynamicLinker.java:228) ~[?:?]
at jdk.internal.dynalink.DynamicLinker.link(DynamicLinker.java:201) ~[?:?]
at jdk.nashorn.internal.runtime.linker.Bootstrap.bootstrap(Bootstrap.java:208) ~[?:?]
at jdk.nashorn.internal.runtime.linker.Bootstrap.createDynamicInvoker(Bootstrap.java:371) ~[?:?]
at jdk.nashorn.internal.runtime.linker.Bootstrap.createDynamicInvoker(Bootstrap.java:345) ~[?:?]
at jdk.nashorn.internal.runtime.linker.InvokeByName.<init>(InvokeByName.java:86) ~[?:?]
at jdk.nashorn.internal.runtime.linker.InvokeByName.<init>(InvokeByName.java:73) ~[?:?]
at jdk.nashorn.internal.objects.Global.<init>(Global.java:96) ~[?:?]
at jdk.nashorn.internal.runtime.Context.newGlobal(Context.java:1111) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine$2.run(NashornScriptEngine.java:350) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine$2.run(NashornScriptEngine.java:346) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.createNashornGlobal(NashornScriptEngine.java:346) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.<init>(NashornScriptEngine.java:143) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngineFactory.getScriptEngine(NashornScriptEngineFactory.java:148) ~[?:?]
at javax.script.ScriptEngineManager.getEngineByName(ScriptEngineManager.java:238) ~[?:?]
at org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:77) ~[?:?]
at org.openhab.binding.modbus.internal.Transformation.transform(Transformation.java:140) ~[?:?]
at org.openhab.binding.modbus.internal.Transformation.transformState(Transformation.java:186) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.lambda$9(ModbusDataThingHandler.java:819) ~[?:?]
at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1553) ~[?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.processUpdatedValue(ModbusDataThingHandler.java:787) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onRegisters(ModbusDataThingHandler.java:667) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.lambda$0(ModbusPollerThingHandlerImpl.java:91) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.onRegisters(ModbusPollerThingHandlerImpl.java:91) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:279) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.lambda$1(ModbusManagerImpl.java:163) ~[?:?]
at org.openhab.io.transport.modbus.internal.SimpleStopWatch.timeRunnable(SimpleStopWatch.java:148) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:162) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:1) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.executeOperation(ModbusManagerImpl.java:571) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.lambda$15(ModbusManagerImpl.java:719) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
Caused by: java.lang.OutOfMemoryError: Java heap space
I don’t understand what this means or the cause. Is it because the modbus-binding or something else?
As I understood, this parameter configures if and if yes how ofter MODBUS Thing will get an update if the status is not changed?
Thing data do08 [ readStart="0", readValueType="bit", writeStart="0", writeValueType="bit", writeType="coil",updateUnchangedValuesEveryMillis="500000" ]
This parameter is not in the documentation. Is it only available on 2.5 snapshot or in 2.4 stable binding too?
And can I set it to false, which means I get only changed Things trigger and no update trigger?
Which means my item only get changed events? This will reduce the load on OH? Because MODBUS will update my items every sec. and I have 100 of them.
Thanks for the hint, I missed this. Can I ask one more question about this parameter
Normally values are not updated unless their value change. In milliseconds.
Does this mean, if I do not configure the parameter the binding only acts on thing change and will update the item?
In an earlier version of the binding I run into a problem with my persistance. I had a config to persist on every update. This slows down OH a lot. I changed persist on every change and it works again. This is why I thought that the modbus-binding sends an update to the thing/item at every poll interval. But this seams not the case. I will try it.
As you found, this can be a problem for any polling binding. It’s frequent polling that is the issue, not modbus as such.
It did. The 2.5 version now gives you an option not to do that for Items. (I believe the data thing is still updated e.g. with lastReadSuccess and so on)
With the expiremental version, the channel is updated when
new state (so the value after read transformation etc) is different from last poll, OR
more than X milliseconds have passed since the last update with this channel where X is the new configuration parameter, default for X is 1000 ms
All channels are treated the same way, e.g. since lastReadSuccess channel value changes on every poll (at least with the default transformation), it would be updated on every poll.
If “updateUnchangedValuesEveryMillis” is set to 0 updateUnchangedValues is disabled, Should I open a PR?
In my use cases I need updates only if something is changed. See no need of getting the same value every time. Does this make sense? Or should I set updateUnchangedValuesEveryMillis to one week?
You can get what you want by using arbitrarily big number. However, please note that with autoupdate=true, the item state might not anymore reflect the true status in case there is e.g. modbus errors happening.
To me at least it makes sense that updateUnchangedValuesEveryMillis=0 updates on every poll takes more than zero millis.
