[SOLVED] Map Transformation only on one Item
  • Platform information:
    • Hardware: RaspberryPi 4
    • openHAB version: 2.5
  • I have two Items with the sam channel. I want only that one Item transform by the map file. My configuration look like this:
String	SZ_HarmonyHub_Aktuell	"Aktuelle [MAP(harmony.map):%s]"	{channel="harmonyhub:hub:Schlafzimmer:currentActivity"}
String	SZ_HarmonyHub			"Aktuelle Aktivität"				{channel="harmonyhub:hub:Schlafzimmer:currentActivity"}
My Sitemap look this:
Switch item=SZ_HarmonyHub label="Aktuell" icon="screen"
Text item=SZ_HarmonyHub_Aktuell label="Aktuell" icon="receiver"
In the PaperUI it look like this:
How can I edit my file, that the transformation only change the text from the Item “SZ_Harmony_Aktuell” but don´t show in front of the Item “SZ_HarmonyHub”?
Tank you
Create a sitemap and use BasicUI for control. You can edit how the item is displayed in the sitemap file.
BTW, PaperUI is for configuration not control.
Sorry, I actually meant BasicUI instead of PaperUI
What’s in your map file?
To suppress state display, use an empty state format [ ] in your sitemap label or in your Item definition label
label="Aktuell []"
You don’t have to give labels in both places. If you do, the sitemap “wins”. If you don’t specify any state [format], you get the default state display.
Thank you, that was the problem.
I change the one Item to:
String	SZ_HarmonyHub	"Aktuelle Aktivität[]"	{channel="harmonyhub:hub:Schlafzimmer:currentActivity"}
And now it look like it should:
The MAP file only transform one Item instead of both.
I haven’t changed anything else.
Thank you!
The MAP transform only applied to the labels that you tell it to apply to.
