OS: Debian 10.0 with java 11.0
openHAB version:Last, downloaded Satarday.
Hello all, following my migration from OH2 to OH3 I’m testing the persistance again using Mysql, it works with the below code without errors but it creates persistance not only to the configured item but also for all the other items! Am I doing something wrong??? Thanks.
jdbc.cfg
url=jdbc:mysql://192.168.1.51:3306/openhab?serverTimezone=Europe/Berlin
user=openhab
password=openhab
tableNamePrefix=Item
tableUseRealItemNames=false
tableIdDigitCount=0
items
String Sala_CPE_rec {channel=“mqtt:topic:MyMQTTBroker:TH_CPE_Pe:TH_CPE_Pe_rec” }
Switch Sala_CPE “Test Light []” {channel=“mqtt:topic:MyMQTTBroker:TH_CPE_Pe:TH_CPE_Pe_SW” }
Number Sala_CPE_TMP “Temperatura [%.1f°C]”
persistance
Strategies {
everyHour : “0 0 * * * ?”
everyDay : “0 0 0 * * ?”
every5min : “0 0/5 * * * ?”
default = everyUpdate
Items {
Sala_CPE_TMP : strategy = every5min,restoreOnStartup
rules
rule “testrec”
Item Sala_CPE_rec received update
if (Sala_CPE_rec.state.toString.contains(“Slave,”)) {
var String[] buffer= Sala_CPE_rec.state.toString.split(",")
if (buffer.get(1).contains(“ON”)) postUpdate(Sala_CPE,ON)
else if (buffer.get(1).contains(“OFF”)) postUpdate(Sala_CPE,OFF)
Sala_CPE_TMP.postUpdate(Double.parseDouble(buffer.get(2)))
//getActions(“telegram”,“telegram:telegramBot:FS6”).sendTelegram(“Test”)
