This is a strange one.
I have had my QMI PowerStrip (5 socket) previously working for many months then around June/July this year it fell off the network and I had to reset it and get it reconfigured. Since then It has not worked correctly at all.
As I recall it used to identify itself as a QMI powerstrip v1 and it was listed as unsupported, but I was able to use channels for getting the power rating in watts and turn it on and off and I believe the internal temperature was also provided.
now it does not set the model identifier and it gets seen as generic without the power usage channel and none of the channels actually function.
I suspect thats because I am seeing this in the debug log and yet it shows as ONLINE.
2018-11-11 20:08:36.003 [DEBUG] [ing.miio.handler.MiIoAbstractHandler] - Received response for 02F1E7DC type: MIIO_INFO, result: null, fullresponse: {"error":"Given final block not properly padded. Such issues can arise if a bad key is used during decryption."}
2018-11-11 20:08:36.003 [DEBUG] [ing.miio.handler.MiIoAbstractHandler] - Error received: "Given final block not properly padded. Such issues can arise if a bad key is used during decryption."
I think the token is correct, is there another reason I may see that log entry?
Regards
Paul
