SOLVED: Mios binding transform not working...ideas greatly appreciated:-)
I have searched the forums for ideas, but to no avail, so I hope some of you can assist me a little bit:slightly_smiling_face:
I am trying to setup the Mios binding and have the house.items file generated and the MAP files in the transform directory - everything looking good, except for the fact that there is no connection between my Vera and openHAB.
I have taken 3 z-wave items and inserted into my sitemap for testing - 1 temp. sensor, 1 motion, 1 door.
The log tells me that the transform is not working:
2018-01-27 20:58:11.085 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ā€˜-’ with the file ā€˜miosDeviceStatusUI.map’ : Target value not found in map for '-'
2018-01-27 20:58:11.098 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ā€˜-’ with the file ā€˜en.map’ : Target value not found in map for ā€˜-’
As far as I can understand the ā€œ-ā€ means ā€œno valueā€. Does that mean that the vera is transmitting ā€œno valueā€? The vera seems to be working fine.
Number   TemperatureSensorCurrentTemperature "Temperature Dining [%.1f °C]" (GDevices,Dining) {mios="unit:house,device:46/service/TemperatureSensor1/CurrentTemperature"}
Contact  MotionsensorTripped "Motion sensor [MAP(en.map):%s]" <motion> (GDevices,Dining, gMotion) {mios="unit:house,device:45/service/SecuritySensor1/Tripped"}
Contact  DrsensorHoveddrTripped "Drsensor Hoveddr Tripped [MAP(en.map):%s]" <contact> (GDevices, Entryway, gDoor) {mios="unit:house,device:33/service/SecuritySensor1/Tripped"}
These are the items i have inserted in the sitemap (for basic UI), where they show as expected but with no values.
As you can hear from the above I am a total rookie, but seeing endless opportunities in openHab so any inputs/ideas you might have to what I am doing wrong are greatly appreciated.
Thanks:slight_smile:
It looks like you did everything right. The only thing I noticed that you didn’t mention was the mios.cfg file that points OpenHAB to your vera IP address.
Hi Mike,
Thanks for your reply.
Yep I forgot to mention but i have set up the file like this:
house.host=192.168.1.69
Is that the correct format?
That’s the same format that I have. Do you have both the Mios Binding and the Mios Action installed?
Not the Mios Action. Is that also required?
I“ll try and install that right away.
I’m not sure it’s required or not, but I have it installed on my system. I was looking back on some of the posts I looked at when I was trying to get it to work. The person who wrote the binding (guessed) mentioned that you need the right version of Java installed.
Awesome:-) I just installed the Mios Action, and 1 second later all the values (door, motion, temp) populated and is working perfectly!
Thank you very much for your help - so nice to get this going!
Cheers,
Peter
I also read about the Java version and had already tried that, but that did not help in this case.
Great! Glad you got it working. I know how you feel. It can be frustrating. I am not expert at this either
