Issue of the topic: I still have some old X10 devices that used to work nicely under OH 2 using the Mochad Binding and if possible I would like to use them with OH 3.
I am aware that OH 1x bindings may not work well with Java 11 but if possible at all would like to give it a try.
Any guidance how to use 1x bindings with OH 3 would be greatly appreciated.
This looks very promising.
Can both local and remote instances run on the same machine at the same time?
One would require Java 8 and the other Java 11.
Another possibility is to use the RFXCOM binding (I have the hardware) to operate the X10 devices by RF and use a transceiver for power line commands.
I know this works well with X10 lighting but not sure if it will work for shutters and blinds. Will check it out. Reverting.
