As mentions above your config looks good. Have you restarted OH since installing and/or modifying any Modbus files? Just asking b/c mqtt 2.x has a bug that requires an OH restart after making any changes to the things file.
Restarting did the trick for me. Now I get a CONFIGURATION_ERROR on the switch-item, but that a thing I look into by myself this evening. Thank you all for your support!
Trying to understand the expectation here. You installed modbus binding, and were stumped enough by it not working without a reboot, that you posted for help?
I’m not saying you’re dumb!! Maybe we need a prompt in the install process.or docs. Suggestions?
the last Bindings/Things I installed (ie.solaredge,http1,fritzboxtr0641) all started without the need to do a restart.
Furthermore the logfiles did show that ModBus (somehow) became active. Thus I was quite sure that the problem was due to a bad configuration.
So this is the first time I ran into this issue (using openhab for several years). I would say that I’m not a total noob and a hint within the ModBus binding page would be quite helpful.
