Hi
I am using OH2 and Modbus Binding 1.9.0
It works perfektly when using basic like this:
Switch dS2824Input1 "Input1" (gDs2824) {modbus="dS2824:24"}
but this is actually only a input. So i try to change to read only, like this:
Switch dS2824Input1 "Input1" (gDs2824) {modbus="<[dS2824:24]"}
This is not working and I am getting error in the consol:
08:56:06.017 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'dS2824.items'
08:56:06.020 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'modbus' of item 'dS2824Input1' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: For input string: "24]"
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:50)[197:org.openhab.core.compat1x:2.0.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:284)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:167)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:347)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
I have tried to folow the instructions in this manual, but am not able to se what i am doing wrong.
Someone that can help me?
