Hello together,
i have got a problem, and need some assistance.
1., i have got a zwave device (door sensor)
2., i have got a zwave-mqtt gateway
3., i have got an openhab with MQTT binding
From the MQTT gateway, for the contact, the JSON is coming. This one i can translate it in the thing definition:
Thing mqtt:topic:GF_LivingRoom_0001:okosotthon:LivingRoom:WindowSensorBig “ZW120_1” (mqtt:broker:C_StorageRoom_0002) @ “LivingRoom”
Channels:
Type contact: ZW120_1_Contact “Contact” [stateTopic=“okosotthon/LivingRoom/WindowSensorBig/48/1/0”, transformationPattern=“JSONPATH:$.value”, Open=“false”, Closed=“true”]
In this case true or false is really there.
In the item definition
Contact GF_LivingRoom_WindowSensorBig_Contact_String “Contact_String” {channel=“mqtt:topic:GF_LivingRoom_0001:okosotthon:LivingRoom:WindowSensorBig:ZW120_1_Contact”}
i have got the error:
Command ‘true’ not supported by type ‘OpenCloseValue’: No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.true
so i have got a feeling that the true will be not “Open” and the false will be not a “Closed”
Where is the mistake, can you please help me?
