I’m trying to set up a MQTT switch in homekit. Everything works great in openHAB but when I add the [“Switchable”] tag, every single one of my homekit items disappears from my phone and the little openHAB “house” hub says "this accessory is not supported.
The offending item is below. Again - in openHAB without the [“Switchable”] everything works properly.
I think I did try it without the state topics. I think I found a fix - I changed the final “ON” and “OFF” to “1” and “0” respectively. It runs properly now - I removed all of my other (30+) homekit switches to focus on just this one so I’m about to see if I am able to add everything back in without any issues.
@vzorglub - that is how I set it up originally, it also did not work but I don’t remember if it was a “homekit not working” or a “MQTT not working” issue.
I think it was a MQTT problem, possibly because the payload coming back from the broker was ON and OFF. Changing the payload to 1 and 0 seems to have fixed things, I can continue my setup like this and should work just fine.
