[SOLVED] MQTT Broken after 2.2 stable
I was using 2.2 snapshot (can’t remember which one - approx 2 weeks old)
but i changed the repo to stable today and upgraded to 2.2 stable
and I’ve lost MQTT control… most of my home!
console log shows items state changing - but it used to also tell me that it was publishing an Mqtt msg.
it no longer shows the msg as being published.
mqtt.cfg is still the same, and the karaf console shows shows the mqtt binding and action as active?
Stuart
Update… uninstalling the mqtt1 binding and reinstalling has fixed the issue
Also i had set logging with log:set DEBUG org.openhab.binding.mqtt
the debug logging was also lost during my update
all fixed now!
Glad you have it all working, we’ll have to keep an eye out on this issue so that you won’t have to do that again! :slight_smile:
