Platform information:
- Hardware: x64/16GB RAM
- OS: Windows 8.1
- Java Runtime Environment: 1.8.0_181
- openHAB version:2.4.0
Issue of the topic:
Hi, I’m using MQTT to show on sitemap the status of my home power contact (OPEN/CLOSED). I’ve also add custom icon (for OPEN and CLOSED state).
I need to change the description that appear in Classic UI:
aperta instead of OPEN
chiusa intesad of CLOSED
Items configuration related to the issue
Contact Corrente “Corrente” (FamilyRoom, gStatus) {channel=“mqtt:topic:plc:mydev:corrente”} -
Sitemap configuration related to the issue
sitemap fadhouse label=“FadHouse” {
Frame {
Group item=FamilyRoom
Things configuration related to the issue
Bridge mqtt:broker:plc [ host=“127.0.0.1”, secure=false ]
Thing topic mydev {
Channels:
Type contact: corrente “Corrente” [stateTopic=“corrente/enabled”]
How can I do?
I try to add MAP to items configuration but it doesn’t work.
Thanks,
Fad.,
