Hello I am using text files to configure the new mqtt binding. When doing so the paper ui shows:
Generic MQTT Thing
Generic MQTT Thing
As the text in a description field. If you use paper UI to build the things this field is editable. Curious is there a way to change this in text config?
I know it does not impact functionality, I was looking for readability.
Thanks,
DAnny
