The problem is, that when homie/eg-bad-licht/light/power change, nothing happens with the item. And when I change the item (toggle switch), nothing are published under homie/eg-bad-licht/light/power/set.
What is wrong?
Thanks for your help.
PS: My Openhab-Version is openHAB 2.5.0 Build #1485 under Debian.
Have you looked up the channel ID (and the Log)? Because dashes are not allowed in channel ids if I recall correctly. I know that node/properties without dashes work perfectly. If dashes don’t work, that’s a bug that need to be reported.
OK, now it works, with boolean and without dashes. With dashes it not work, this was the reason, why i have change to enum.
Can you open the issue with dashes?
This is what i’ve come up with, with my interpertation of docs and examples. However this generates two dummy channels in the Homie MQTT thing. They are not of type switch. Any idea what I could be doing wrong here?
Hi I see you guys say that in OH 2.5 you can use an ENUM for MQTT discovered swtiches but I’m not able to get this to work. I’ve used the format to set the enum options as on:off and ON:OFF etc. no matter what it detects as a string type. Any suggestions or is this still not possible and requires a boolean?
