I have a light item which is controlled over MQTT. I have made an external button control which also works through MQTT to turn on/off the lights. The sitemap turns on/off the lights correctly and my external button turns on/off the lights correctly as well, however, I’ve noticed that the status of the lights does not update on the OpenHAB sitemap when I toggle it through my external button control. The external button publishes to the topic /home/patio/pergolaLights/out
. Here is my item configuration:
Switch pergolaLights "Patio Lights" <light> {mqtt=">[mosquitto:/home/patio/pergolaLights/out:command:ON:1],>[mosquitto:/home/patio/pergolaLights/out:command:OFF:0],<[mosquitto:/home/patio/pergolaLights/out:state:default]" }
Is this how my inbound item configuration is supposed to be, or does it have something to do with autoupdate that I didn’t include in the item configuration?
