I have some switches/numbers that in MQTT I used command rather than state because i wanted them to re-trigger a rule/whatever.
I tested that it would work via “is command” switch via paperui when creating a channel but I like to use the .things files still. What is the .things file version of “is command” ?
I made a generic thing in paperui then looked at the json db for it
You need to have state defined as well as command and then add postCommand=“true”
example:
Type switch : doorSwitch "Garage Man Door" [ stateTopic="/garage/garageManDoor/GMD", commandTopic="/garage/garageManDoor/GMD", postCommand="true" ]
