I think I have it working now, I’ll keep an eye on it during the day
Thank you for all your help.
If i was to try and grab another value from the string in the same script could i just add the below
WatchmanTemp.postUpdate(transform("JSONPATH", "$.temperature_C", WatchmanTemp.state.toString))
val float temp = Float::parseFloat(WatchmanTemp.state.toString) as Number
WatchmanTemp.sendCommand(temp)
When I add that I get the error:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Update oil level': For input string: "NULL"
One line should be enough
val Number height = 89 // height of the tank
rule "Update oil level"
Item RawJson changed
val String id = transform("JSONPATH", "$.id", RawJson.state.toString)
if (id == "141932971") {
val Number depth = Float::parseFloat(WatchmanDepth.state.toString) as Number
val Number left = height - depth
val Number per = (left / height) * 100
WatchmanPercentage.postUpdate(per) // update the item that holds the percentage
WatchmanTemp.postUpdate(transform("JSONPATH", "$.temperature_C", RawJson.state.toString))
I have expanded it slightly to send out more info to other items for display on sitemap (litres, temp and percentage) plus depth for grafana
val float height = 90 // height of the tank
Item WatchmanCalc changed
val String id = transform("JSONPATH", "$.id", WatchmanCalc.state.toString)
WatchmanDepth.postUpdate(transform("JSONPATH", "$.depth", WatchmanCalc.state.toString))
val float depth = Float::parseFloat(WatchmanDepth.state.toString) as Number
val float left = height - depth
val float per = (left / height) * 100
WatchmanPercentage.sendCommand(per) // update the item that holds the percentage
WatchmanTemp.postUpdate(transform("JSONPATH", "$.temperature_C", WatchmanCalc.state.toString))
val float litre = (left / height) * 1200
WatchmanLitre.sendCommand(litre)
WatchmanDepth.sendCommand(depth)
When this runs with dummy data im sending (I can’t wait 40mins between transmissions) I get the following logged
```csv
2019-01-15 21:22:20.500 [vent.ItemStateChangedEvent] - WatchmanDepth changed from 99.0 to 25
2019-01-15 21:22:20.509 [ome.event.ItemCommandEvent] - Item 'WatchmanPercentage' received command -10.0
2019-01-15 21:22:20.519 [ome.event.ItemCommandEvent] - Item 'WatchmanLitre' received command -120.0
2019-01-15 21:22:20.527 [ome.event.ItemCommandEvent] - Item 'WatchmanDepth' received command 99.0
2019-01-15 21:22:20.538 [vent.ItemStateChangedEvent] - WatchmanDepth changed from 25 to 99.0
The correct dummy data gets stored but then it reverts back, I am sending 25 as depth but it reverts back to a previous set number of 99.0
EDIT - I think I have it going now, I didn’t need the SendCommand for temp or depth as it’s already being posted above, grafana is getting the data now and it’s not duplicating itself.
Steep learning curve for me but I’m slowly starting to understand!
EDIT 2 - Not 100% but the script needs to run twice before it calculates percentage on a depth change. If the depth changes, script runs but it doesn’t update anything. The next time it polls it then generates the percentage and so on. Why would this be?
It’s likely to be useful to insert logInfo into your rule to see what it is doing
e.g.
logInfo("calc", "id " + id)
and so on
Negative percentage looks a bit odd, but I’ve not followd your calculations.
You are updating item and then sending a command to them why?
WatchmanPercentage.postUpdate(per) // update the item that holds the percentage //postUpdate
// val float temp = Float::parseFloat(WatchmanTemp.state.toString) as Number NOT NEEDED
val Number litre = (left / height) * 1200 // Number not float
//WatchmanLitre.sendCommand(litre) postUpdate instead
WatchmanLitre.postUpdate(litre) postUpdate instead
// WatchmanDepth.sendCommand(depth) NOT NEEDED
// WatchmanTemp.sendCommand(temp) NOT NEEDED
Sorry, I should have updated the previous post with where I was at.
See below. It takes two runs of the script for it to calculate litre changes.
If I send a payload with depth at 40 (from previously being 51), the script runs picking up the depth change. The next time a payload comes through the script is triggered again where it then calculates the litres. I don’t understand why it can’t do all the calculations on the first pass, why does it need to have to be ran twice?
Because of this:
You are posting an update to the item and then read the item state in the next line. BUT the item state has not yet been updated. It takes time for the event bus to react.
Change it to:
val depthString = transform("JSONPATH", "$.depth", WatchmanCalc.state.toString)
WatchmanDepth.postUpdate(depthString)
val Number depth = Float::parseFloat(depthString) as Number
Also change:
To:
aaahhh, interesting.
thank you, so far so good. Was stumped for a bit as I had mistyped something as simple as a capital which I now know can throw the whole script off!
I’ll report back any further issues
