Hi
I have an issue to display mqtt string outputs.
my items below
Number mqtttemperature "A1 Temperature [%.1f]" {mqtt="<[mosquitto:broadlink/mqtt_A1_1/temperature:state:default]"}
Number mqtthumdity "A1 humdity [%.1f]" {mqtt="<[mosquitto:broadlink/mqtt_A1_1/humidity:state:default]"}
String mqttnoise "A1 Noise" {mqtt="<[mosquitto:broadlink/mqtt_A1_1/noise:state:default]"}
String mqttlight "A1 Light" {mqtt="<[mosquitto broadlink/mqtt_A1_1/light:state:default]"}
String mqtt_airquality "A1 air_quality" {mqtt="<[mosquitto:broadlink/mqtt_A1_1/air_quality:state:default]"}
my sitemap
Frame label="Sensors-A1" icon="temperature" {
Default item=mqtttemperature
Default item=mqtthumdity
Default item=mqttnoise
Default item=mqttlight
Default item=mqtt_airquality
as you can see the mqttnoise is well updated
2018-03-26 16:46:58.132 [vent.ItemStateChangedEvent] - mqttnoise changed from NULL to Normal
MQTT string is not displayed
moreover, i have another issue:
2018-03-26 01:48:00.746 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-03-26 01:48:01.224 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-03-26 01:48:01.302 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-03-26 01:48:01.361 [INFO ] [b.core.service.AbstractActiveService] - Exec Refresh Service has been started
2018-03-26 01:48:01.645 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type âmqttâ of item âmqttlightâ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Configuration âmosquitto broadlink/mqtt_A1_1/light:state:defaultâ is not a valid inbound configuration: Configuration requires 4 or 5 parameters separated by â:â
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:51) [202:org.openhab.core.compat1x:2.2.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:294) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:131) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
at o
Any ideas
