Issue of the topic: I have some items connected to tasmota mqtt switches.
Everything works fine but for what ever reason the switches on the sitemap shows a text representation of the status and i have no idea where it is coming from because i’m not using any formatting what so ever.
But is there a reason why it happens in the first place!? if i have already identified the channel type to be Switch why it is still perceived as String!?
It’s not perceived as a string. A switch has a state ON, which is represented on screen as the letters O and N.
Most of the UI widgets allow display of state alongside the graphic, e.g. 55% beside a dimmer slider. If you don’t like the default, your means of control is the [formatter].
I’m just wondering because i have many other switches from different channels (zwave, zigbee, …etc.) which doesn’t show this “ON”/“OFF” status at all without using formatters.
