Hi guys,
I had MQTT Actions set for MQTT1 version i need little more help.
This is my rules file:
rule "rPCControl"
Item PCControl received command
logInfo("rule rPCControl", "command "+receivedCommand)
switch (receivedCommand) {
case "nhk" :
publish("broker", "winthing/system/commands/run", "[\"nhk.vbs\",\"\",\"\"]")
case "youtube" :
publish("broker", "winthing/system/commands/run", "[\"youtube.vbs\",\"\",\"\"]")
case "netflix" : {
publish("broker", "winthing/system/commands/run", "[\"Netflix.lnk\",\"\",\"\"]")
// Wait 5 seconds and send WIN+SHIFT+ENTER to go Fullscreen
Thread::sleep(5000)
publish("broker", "winthing/keyboard/commands/press_keys", "[\"LWIN\",\"LSHIFT\",\"ENTER\"]")
In this link
is following example
rule "On system start"
System started
val actions = getActions("mqtt","mqtt:systemBroker:embedded-mqtt-broker")
actions.publishMQTT("test/system/started","true")
I set up the my mosquitto MQTT broker in PaperUI it shows online and has id
mqtt:broker:81c98b85
Now how do i fill in the “val actions”?
EDIT (for completenes including the full solution)
rule "rPCControl"
val actions = getActions("mqtt","mqtt:broker:81c98b85")
case "nhk" : {
actions.publishMQTT("winthing/system/commands/run", "[\"nhk.vbs\",\"\",\"\"]")
case "youtube" : {
actions.publishMQTT("winthing/system/commands/run", "[\"youtube.vbs\",\"\",\"\"]")
case "netflix" : {
actions.publishMQTT("winthing/system/commands/run", "[\"Netflix.lnk\",\"\",\"\"]")
Thread::sleep(5000)
actions.publishMQTT("winthing/keyboard/commands/press_keys", "[\"LWIN\",\"LSHIFT\",\"ENTER\"]")
