I am trying to recreate the setup where three different state messages can be received to set the value of the same Item. The way I have set it up does not update the Item value. No information messages associated with this Item appear in the log.
In mqtt1 I defined three incoming MQTT messages.
In mqtt2 I created a Generic MQTT Thing with four channels.
- The first channel receives the switch state and issue the switch command. The Item linked to this Channel works as expected.
- The remaining Channels (3) each have a unique Channel ID and state topic. The state topic for each Channel corresponds to the same topic I had in the mqtt1 Item declaration. I have included a screenshot of the declaration of one of these Channels showing the topic and the JSONPath transformation. Again, the JSONPath corresponds to the same transformation I used in the mqtt1 Item declaration. I copy and pasted the string srom my mqtt1 Items file over to PaperUI. I have the same Item linked to each of those three Channels. with mqtt2 is it allowed to link the same Item to multiple Channels?
mqtt1 Items
Switch cwiHouse_FF_laundry_washer
"Washer"
["Switchable"]
{ mqtt=">[openhab_tcpbroker:cmnd/sonoff-washer_monitor/POWER:command:*:default],
<[openhab_tcpbroker:stat/sonoff-washer_monitor/POWER:state:default]" }
Number cwiHouse_FF_laundry_washer_monitor_power
"Washer Monitor: Current Power Load [%d] W" <none> { mqtt="
<[openhab_tcpbroker:tele/sonoff-washer_monitor/SENSOR:state:JSONPATH($.ENERGY.Power)],
<[openhab_tcpbroker:stat/sonoff-washer_monitor/STATUS8:state:JSONPATH($.StatusSNS.ENERGY.Power)],
<[openhab_tcpbroker:stat/sonoff-washer_monitor/STATUS10:state:JSONPATH($.StatusSNS.ENERGY.Power)]
I have set up the broker (mosquitto) and created the Broker Thing. It is connected and ONLINE
mqtt2 Things
mqtt2 Items
"Washer"
["Switchable"]
