I’m just in the process of moving my item configuration from the .items file into paper ui. For some reason, I can’t get the map transform to work properly. In paper UI, I’m configuring the map transform under the channel of a “thing”, using the “Incoming value transformation” field.
My thing is a thermostat, the channel is the thermostatFanOpState, and the transform is entered as “MAP(thermostatFanOpState.map):%s”. The .map file is available in my filesystem under conf/transform. When a state update comes in for this channel, I get an error in the openhab.log that reads ‘Transformation service “[MAP(THERMOSTATFANOPSTATE.MAP) for pattern %s]” not found!’. I’m looking at the channel and see the value “0” coming in, and 0 is mapped to “Off” in the .map file. This same map file works if I apply it to an item in a .items file.
The thermostat is set up as a generic MQTT thing, using the MQTT binding. I’m able to see the state updates come in via MQTT, but it’s complaining about the transformation.
How should a map transformation be set up on a channel in paper UI using the “incoming value transformation” field? The openhab documentation on transformations seems to assume the item is configured in a .item file.
trying the same thing. I have an mqtt Thing (“generic MQTT Thing”, my lawnmower) with several channels linking to several items.
One channel is the status which comes as a number and should be translated into a String.
I defined a channel (type “Text value”), with the mqtt topic as state topic.
In the incoming value field I put: MAP:mowerstatus.map
In $OPENHAB_CONF/transform, I have a file “mowerstatus.map” that has the appropriate key=value pairs:
0=Detecting
1=Parking
2=Mowing
3=SearchingStation
4=Charging
5=Searching
7=Error
8=Missing Loop
16=Off
17=Sleeping
18=Waiting for Door
98=Offline
99=Unknown
=Mystery
However when I look at the Control, I see the numeric value rather than the transformed string.
What am I doing wrong? ( I see no errors in the logs…)
